Towing With Avalanche 1500
Hello all, new to the board, been doing allot of reading, this is my first post. I'm towing a 4700lb TT with my '04 avalanche 1500. It has the tow package, 373 gears, I've added a trans cooler also. I live in PA where flat earth is an oddity. On long hills (in the summer) my temp gauge will rise to about 220-230, but so far she hasn't overheated, I tow in 3rd (not OD). It always runs just under 210 Does this sound normal? Was thinking of installing an engine oil cooler, and/or, heavy duty fan (replacing clutch fan). The electric fan kits look good too but are pricy. Looking for some inexpensive ideas to keep cool. thanks :lol:
I have been towing across the PA mountains for 6 years, 8-10 times a year, with an 8K# trailer. I've done it with 8.1's, 6.0's and now a 6.2/6sp. My temps get to 220's on 90 degree days, and only on the 380 hill by Strausberg, mostly stays 190-200 everywhere else. I doubt there is anything you can do to lower the temps. Keep the fluid changed, or see if it has, or you can move to Dextron VI. You really need a 6.0 minimum to do the job with 5K#'s, but I don't think Av's come with it. If you only do it a couple times a year, no biggie, just don't look at the temp.
note: on my recent pull up the 380 hill, i experimented by leaving the foot in it all the way up. It was 85 out, and the engine stayed at 4000rpm+ (not my first choice), I stayed at 60mph!, and the trans didn't go over 210-215, maybe 10 degress cooler than letting it struggle up the hill. Didn't sound great, compared to my normal method, but she certianly stayed cooler, and I was safer at 60 then 45.
ps: you should weigh your trailer if you haven't. I have two, one says 6500 on the sticker, and weighed in at 7500 loaded, and the other is a toyhauler which says 5500 on the sticker, but we load it to 7700 loaded. I really need a diesel or the old 8.1 (not avail. anymore), but I tried the 2500 route and can't deal with the HD ride the 350 days a year i'm not towing. So I bought the 6.2/6sp out of necessity, and it works pretty well for my needs. The new 4.5 diesel in Burb's, if they put it in them, might be the ticket for me in a couple years.
Yeah, I agree with the above. Your truck is not the proper truck to pull that much weight in that terrain. To help, I'd suggest investing in a high-quality trans cooler (stacked plate, you don't specify what you have), going to a lower temp thermostat, and getting a programmable set of electric cooling fans. An engine oil cooler might help if you're seeing your engine oil temps climb, but those generally stay with the coolant temps.
Glad to hear that you're towing in 3rd, too many people these days just presume that OD is all they'll ever need for whatever they're pulling.
Thanks for the replies. I'll probably be towing 6-8 times per year. I don't have a trans temp gauge, just reading the coolant temp gauge. Trans cooler is flex-a-lite fin cooler rated for 17000 (11in x 17in x 1in). GVW. Trans fluid is staying red, so far so good. Truck is rated to tow 7100lbs, trailer is at 5000lbs loaded up. And yes she heats up on the hill before I-380 coming out of stroudsburg, PA. Just wondering if an engine oil cooler will help keep the coolant temps normal while towing uphill or if more CFM's through the radiator (electric fan(s)) would work better.
Paul,
I can offer some advise, some of which you have already heard.
I tow a 6500 TT with a 1/2 ton Yuk XL. I run coolant temps around 197 to 202 and trans temps in the mid 160s to low 170s on a 95 degree day. However, I am not pulling hills as you are.
First of all, you need a Trans Temp Gauge. Look at the Interceptor by Aeroforce or other similar scan gauge that will simply plug into your OBD II port.
The tube and fin cooler you have is not as efficient as a stacked plate designed cooler but you have added a very large one "11 x 17" which should function about the same as a 11 x 11 stacked plate cooer. The biggest advantage of a stacked plate cooler is they are less restrictive to the flow of the fluid and they offer more cooling efficiency is a smaller space. Where do you have your cooler mounted? Do you have it in series with the fluid still running through the radiator and then through the cooler? This is the preferred method.
I do not necessarily agree with the e fans. Not that they would not work well, but your OE mechanical fan should be pulling more than enough air through the radiator. I have always joked that they will pull small animals and children in the grille if the clutch is engaged. Make sure your fan clutch is working properly and the front of the radiator and A/C Condensor are not plugged with bugs and junk.
I do not have any experience with a lower temp stat on a 5.3. To my knowledge they are only avail from companies such as Hypertech and are designed to help performance on a truck that has been tuned. Typically, a cooler stat will not lower overall temps as they only open sooner, not more. In other words, they simply open at 165 instead of 186. Once the coolant reaches temps above 186, the stat is wide open anyway. I could be wrong but I do not feel this would help you.
An engine oil cooler would likely help. Many 3/4 and 1 ton trucks come with engine oil coolers and they also use mechanical fans with a fan clutch. If you decide to go this route, you want a stacked plate oil cooler.
Hayden now offers a device called The Mister. It is a simple device that mounts a 2 to 3 gal container somewhere under the vehicle or in the bed and routes cool water to sprayers mounted in front of the radiator. On a hard pull such as you are speaking about, you push the button and spray cool water into the front of the radiator. If you have ever noticed your temps fall when you run through a cool rain, this operates in a similar manner. We (CARQUEST) sell them but I do not have a catalog with me at this time to give you a part #.
One last thing. Lubegard and other companies make a coolant additive that is a wonderful product. Lubegard calls theirs Kool It and the # is 96001. It is not a miracle in a bottle but would drop your temps around 3 to 7 degrees. It also is a great product for eliminating electrolysis in modern vehicle cooling systems. This the primary reason we sell so much of it.
Good luck and let us know what you do. 220 to 230 is not terrible and certainly not overheating. However if you can get them down by 10 to 15 degrees, I would be more comfortable.
Hi there and welcome to the forums!
unfortunately I don't really have any suggestions beyond what people have already suggested.
I have an 08 Avalanche - 5.3l 3.73 rear end and I added the GM transmission cooler. I just towed a UHaul car carrier with a 3,700 Toyota on it from Denver to Austin (900+ miles) during 100 degree outside temps and lots of hills (Monument Pass, Raton Pass, etc.). On some of the steeper inclines transmission temps got to 225 but came down pretty fast once the pass was summitted. Coolant temps went to 250 during that time but came down the same as trans temps. Once on level terrain, temps stayed in pretty normal ranges (180-195 for trans and 210 for coolant). I have the tow haul feature on the trans and I used that. Truck ran great.
250 for coolant temps makes me hurt. I realize this is not really considered to be "overheating" but dayum, that is hot. Of course with a 50 50 mix of Dex cool and water and the proper PSI in the cooling system, your boiling point is 265 degrees.
That bothered me too - I forgot to mention that I had A/C on too for most of the trip. When the temps started to climb I shut A/C off. Never had the temps max for more than 5 minutes. The coolant temp dropped very quickly (within 30 seconds) after removing the load of climbing up the mountain - took longer for the trans temps to drop.
Thanks again for the repiles guys. The thing that bothers me about the higher coolant temps is the fact that the stock trans cooler is in the radiator....so if coolant temp is say 220, would that be the temp of the trans fluid sent back?? Would it be better to just bypass the radiator trans cooler and use the aftermarket alone in the summers at least??
I would not recommend bypassing the internal cooler. It is still "cooling" your fluid to some degree. Just imagine the fluid entering the interanl cooler at 280 or so. The 220 degree water in the radiator helps reduce the fluid temp to some degree. It then enters the aux cooler which further cools it before sending it back to the trans.
The internal cooler is also very important in cold winter climates to help bring the fluid up to operating temps.
I would have to think your best option would be the Mister unit I mentioned. I am not sure but I think it sells for less than $80.00 and is a complete kit containing everything you need.
After reading the temps you guys are seeing pulling a really big incline, I am going to seriously consider installing one before I ever plan a trip out west or to any other mountainous region.
Have you installed one of those bolt on grilles over your original grille? Or changed the grille?
I Know a couple guys that did that, and had higher temps because of that, while towing.
I don't think that you can conclude that there is a completely direct correlation between coolant temp readings and the trans fluid temp return, as you really can't tell how much the trans is contributing to the overall coolant temperature. You would be wise to invest in a transmission temp guage.
original grille, stock fan and radiator, thanks for asking
