Ac Contols Panel
Anything CAN be done.
I'm sure they would work IF you got all of the needed parts. There are probably control modules, wiring harness, and maybe even air control motor differences. It might turn into a nightmare if you didn't have a "donor" vehicle to get all of the parts off of. It won't be as easy as swapping the controls.
    • here is the high speed control wiring, i would also be checking  and cleaning ground connections high speed fan control.pdf
