how do you separate the solenoid from the can, it looks like there is only an o-ring there, is there some special tool or method for this? ok once i got it out from under the truck, i could see it was a twist out once you release the tab.
how long does it take for the cel to clear.... or should i just pull the bat cable?
Edited by butzers09silverado
Replaced mine today with AC-Delco 214-2149 purchased from Rock Auto, $21 shipped priority mail. CEL light went out first time I started it after. Simple replacement, no more topping off for me though!
Edited by TooTall1
Hello.
I just bought a 2003 and got under there and it looks like the canister is above the tank in between the bed and cab. Nothing mounted to the frame rails. I have done this before to a 2006 crew I had and it was in a different spot.
Any help before I crawl under there?
  • 5 months later...
I haven't seen anyone ask what is the advantage to the valve with the remote filter over the one without it. Why did GM go to the filter version on the 2007+ models?
Edited by tcfulmer
The filter is designed to be mounted in a less dusty location. The 800 series did have a problem with the valve mounted filter plugging up from dusty road conditions
Edited by txab
I replaced the factory 214-2082 with a 214-2149 as suggested and not problems so far. Codes have been gone for four days. The whole thing took about 15 minutes. Had to use a heat gun to get the canister hose to release from the old unit and put it on to the new unit with a hose clamp. Capped the hose for the remote filter and zip tied it to a fuel line in case I ever need to use it again.
  • 3 months later...
  • 3 months later...
Mike,
The part you ordered will work fine, just did the same to my 07. I just zip tied the breather hose out of the way. Started the truck up, cleared the code and so far so good. You only need the part, hose, two hose clamps a screwdriver and a knife or razor. It took all of ten minutes.
Gil
Ok I am confused on which hose to cut and zip tie up? The one going up to the gas filler area or the one running back towards the engine?
This is where I'm at right now..moved spare, pulled cannister off tabs, unplugged electrical but unsure what to cut and what I need heater hose for? Forgot to add I bought 214-2149 to use on my 2008 suburban so sounds it only has one connection.
Sent from my iPhone using Tapatalk 2
Edited by clf2427
I'd clear the code or have it cleared by someone with a code reader capable clearing codes. You can try disconnecting the battery for a bit
Edited by txab
  • 7 months later...
Hi guys, first time here, had a 2005 chevy 2dr. 5.3 cannot put gas, after read some information notice that the canister vent valve solenoid has missing, I bought it and when I installed has came out of the the line!!! I don't have idea what happens, any assistance will be great.
Thank you
    • I have an Autel, works great for what it is. Can't do some specific things because you need say the GM tool, VCDS for Audi/Volkswagon and others of course. But those times are few and far between for me.   The other tool I'd like to try one day is the new Topdon scan tools. Seen several video's on them and many youtube people review them.    I've never subscribed for updates or payed to do that stuff on my Autel, so I'm sure I'm missing out on some of the updates but I'm fine with that for now.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
