Stainless Steel Brake Lines?
My 03 1500, 4wd, extended cab, long bed has a rusted out and blown brake line. It is the very long one from under the hood to the rear axle. The underside of my truck is a real mess because of the bad conditions at the Jersey shore so I might as well start now with replacing with stainless steel lines. Does anyone know where I can get this? I found a source for stainless for a 01, ext cab, long bed, 2wd but they do not know if it is the same as my truck. Can anyone tell me if it is the same part? Maybe I am the lucky first one to have this happen?
Is your problem with one of the hard metal lines??? I don't think anyone in the aftermarket makes replacements for the hard lines that run the length of the truck. I've only seen SS replacements for the soft lines. I have Russell SS lines on my 99.
Yes. I need the long, hard line from the engine compartment to the rear axle. Classic Tube manufactures this in stainless steel for an 01, ext cab, long bed, 2wd but they do not know if it will fit my 03 4wd. I have also not found bulk ss tube that I can bend and fit myself.
You might give these guys a try: http://www.fedhillusa.com/
Here's another one: http://www.rjays.com/Brakes/brk-lines-01.htm
