Service Stability Dic After Replacing Steering Shaft And Steering Gear
yukon_denali_05
I replaced by steering gearbox and intermediate steering shaft on my '05 Yukon Denali XL. I brought it to a local mechanic to get it replaced. I got the vehicle back yesterday and my "Service Stability" indicator on the dash was on. The mechanic said that he was going to look into it. He called me and said that because the vehicle was on the lift, i have to drive it for about 75 miles for it to stop appearing as the air ride is reseting. The weird thing is that I don't hear the air ride system kicking in when I start the truck - i usually hear it kick on. Does anyone know what it can be?
Your mechanic is a ...... ok I'll be nice wrong. Was the light not on before the repairs?
Tell me about it. That's why I'm doing my research and really do appreciate everyone's feedback.
The Service Stability DIC came on, only after the repair was done. In addition, some of my bulbs on the steering wheel control (radio seek button) are not working. The button functions but the bulb seems to be burnt out. Dont know if its possible to short it out when removing the steering column and trying to put it back.
Anyway, I called him this morning and asked whether he even did a code scan. He told me that he did but did not pick up any error codes. He told me to drop it off tomorrow to take a look at it again. I did also tell him that my steering control bulbs burnt out after I got it back from him. Not sure whether I should bring it back to h im.
Suggestions anyone?
Suggestions anyone?
If the Service Stability message is on then there is a code in the stability system. The steering collum does not get removed to replace the shaft so I would say that your function bulbs being inoperative is a coincidence.
Suggestions anyone?
Unless your dealing with a idiot that has no clue what there doing, I have seen people take stuff off that has nothing to do with what they are working on. :shakehead:
  • 2 years later...
I replaced the pitman arm and had to remove the power steering gearbox. When I drove and made the first turn the Service Stability message came on. I noticed that it turns on in the first turn and when I park the front wheels left or right. I think its a sensor from the steering wheel or maybe the steering column( if there any sensors there). I'm trying to fix it myself if I can. How did you get your denali fixed?
Do you realize this thread is from sept 08?
Mark
I already scanned it the fist thing that came out was "Primary Sys Electrical Suspension Control" Diagnostic trouble codes:computer failure or no controller available. "Secondary System Engine/PCM" diagnostic trouble codes: Did not read engine PCM. User action required test manually. "Secondary System Rear Wheel Steer" diagnostic trouble codes: Computer failure or no controller available. I'm just going to try taking it to the dealer hopefully its not a lot of money.
All these DTCs are likely secondary system error codes that usually don't show up (or won't show up correctly) with a normal scan tool. I can't speak for GM but when I was at Hyundai some models required you to set steering wheel "center" after any front end work (even something as simple as an alignment) using the scan tool. If any electrical components were unplugged for this work to be done the truck's control systems may be able to "tell". It might be possible that GMs need to have the steering wheel centered like Hyundai required. Based on how you describe the message appearing, it definitely sounds as though it has something to do with the steering angle sensor or similar component.
Thanks for the info! I scanned it (for the last time) and yep its a sensor. Secondary System Body Control c0472 steering hand-wheel speed sensor circuit low and c0455 steering angle sensor performance. I think I have to take steering wheel off but I'll look at the manual.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
