New Here
caddy39
Hey Fellas,
I'm from Barrie,Ontario,Canada.
I grew up with Chevys and I will be purchasing one in the next few weeks. I will be here looking for info from you guys "the experts"
Hope all is well
Michael
Welcome. Watch out for the Clowns and the Wookies. :drool: Oh, and Dan. :D
Why the f*ck should he watch out for me?
After what happened with 'that one guy' (may he, and his orifices rest in peace), I stopped... :D
:D
Oh, welcome to the site. :thumbs:
And don't worry, nobody's actually going to go after your holes. :drool:
Welocme...please post some pics after you make your purchase
Welcome to the site.... see if you can get the make ready guy to debadge your truck before you sign on the dotted line.. :jester:
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
