2005 Suburban Tranny Messed Up, Help
Hey guys...
i'm writing on behalf of my father. He's really bummed out right now... both about the market and his truck.
2005 suburban... NATURALLY, the truck was bought about 2 months before GM started the 5 year powertrain warranty...
42,000 miles on it.. never an issue. driven like a baby, never towed anything.
the tranny is slipping bad. get in the car, hit the gas and u gotta play with the gas to get it to shift, it just wont engage gears, slips... it struggles to do anything. it's kind of parked in front of the house right now with no intention of driving it, it's not really driveable it seems to be so slippy... not that it will be in 3rd and slip down, but it jsut wont shift... it gets hung up in the gears too long and sometimes wont ship at all until u start all over.
any help!!?!? i'm trying to do board searches here and read as much as i can...
we have no warranty on the truck
Thank you fellas
This could be an electrical problem. 42K isn't enough to wear out the internals. I'd tow it to a shop and get it checked out. It isn't going to be a driveway fix but it might not be nearly as bad as you think.
EDIT: Has the fluid been changed? I assume it is full?
Check the tranny fluid level. Does the fluid look and smell normal? Are there any signs of leaks from where the truck parks? It may be that the TCM has gone bad and isn't sending the right signals to the transmission. But good luck with this!
fluid is proper level and is very clean... nice clean clear red fluid still in there
no signs of drip or leak
All the more reson to believe that the problem is in the electronics. I'd have it diagnosed by the dealership.
It is possible to kill this transmission in less than 40k miles, but you have abuse it like my neighbor did - constantly towing a 9K lb trailer in town in 'Drive" with no tow mode engaged. Other than that, these are pretty good transmissions. As mentioned, take it to a dealer for diagnosis first, then decide what to do with it.
Hopefully it is something easy and inexpensive to fix. Clean fluid is a good sign.
can bad gas be connected with these symptoms in anyway u think?
coincidence or not... truck was filled up with fuel, no more than 5 miles later the issue started showing it's face and got worse and worse VERY rapidly the more you drove it.
what's the chances the most recent fuel fill-up could be connected?
i'm tempted to go drive it right now and try shifting it manually with the gear selector...
gotta call chevy dealer monday morning, but i'm brainstorming between now and then anyway.
just to give you guys an update...
the tranny did take a chit :confused:
we were out of warranty by 7,000 miles and 7 months.... 05 suburban with 43,xxx miles on it
apparently some spring mechanisms or something that hold the sprags and plates in place or something popped out of place or something....
the rebuild consisted of all new sprags, new plates, new gaskets, tranny flush, it was a complete overhaul....
we did not fight, we did not get aggressive... we dropped the truck off, said listen, we are out of warranty so please call us before you commence any work we dont really know how bad of a bill we're in for...
they had the car for 4 days in total from time we dropped it off, they tore the tranny down ordered parts and re-assembled and called and said it was ready
it did not cost us a red cent! the dealer put in a call the GM, and they covered the entire job even tho we have no coverage.
truck runs and shifts just like normal now.
we are STILL satisified GM customers....
wow.....thats awesome that they did that all for free...i know that rebuilds can be expensive so thinking its gonna cost a pretty penny and then ending up free must be an awesome feeling!
Sweet! :confused: That is great the dealer fixed it for nothing for you Dad!
Probably because the tranny should not have done that with that few miles.
It sounds like you've got a good dealer there that is willing to keep their customers happy.
I'm glad the truck is back running properly for your Dad.
the tranny did take a chit :cheers:
That is great to hear! :confused::confused:
