Bilstein Leveling Installed!
You know you wanted another leveling thread! :jester:
Installed the struts and rear shocks. I gained just over 1/2" more height compared to the CCM kit. I didn't think it was possible to improve the ride of these trucks, but man I am impressed!
There are 4 settings for the spring base, stock through 2.5"
Threw the stock wheels and tires on for winter, my Blizzaks are still on backorder.
**FOR SALE: One GENTLY used CCM Leveling Kit, $70 FedEx'd to your door!** :cheers:
Pardon the dirty truck and the snowflakes!
In case anybody wondered how much difference there is between a 275/55R20 and a 275/60R20:
Looks good. Seeing that you put the factory 20" wheels and tires back on the truck and showed the comparison between the 275/55/20 and the 60's. It really helps me to think of what I'll be looking at with mine of I do a leveling kit and tires... How much larger a tire can you run now with the Blisten package?
I really think the 33" is going to be it without trimming, but I am not sure. I would love to go to a 275/65 which is a 34.5" but people are saying you cant do it.
I sure wish someone would try with the stock wheels and let us know.
Hey Scott, it will be interesting to see if your "Mystery Clunk" will be gone now. Pretty sure I will be chasing that one again as soon as the cold weather hits on a regular basis.
Looks great, Scott! Welcome to the site.
Now, de-badge that thing!!! Also, we like to use the GMT designations around here rather than OBS, NBS, and NNBS!
Oh, also, try searching next time!!!
:jester:
Yeah, I need to find your thread on that TSB for the step bars again. I have been meaning to take care of that. I gave up on the dealer visits, it magically disappears when I take it in for that.
Don't waste your time, that was not it. It never made sense anyway, since it is cold-weather dependant.
I suspect body mounts.
I think I have a friend running the 34.5" tires on an 07 suburban... I check and see what it is he is running and see if he'll let me take some pics. I think he did some trimming.
Looks like a real high quality kit. :jester:
What do your CV/tie rod/ball joint angles look like?
And that snow makes me :cheers:
Dan, it looks fine. 1/2" more, about the same as the Truxxx kits...only cooler :lol:
:D
Um, thanks, Tobias. I think :lol:
That would be great! Let us know!
ya know, mine clunks when its cold too. And...since mine is parked only a few blocks from yours in the daytime, when it actually gets COLD out, you should stop by and see if they are the same clunk. Then I can waste a bunch of time at the dealer instead of you and when they fix mine, you can get yours fixed too!
Sounds good, Jared. I will bring it by when it does it. Only seems to act up when the weather is below 15*. Then I drive it in the service bay and it warms up!
Does yours have step bars? That is the area my noise seems to come from, the floor or firewall area possibly.
Mine has no bars. Stock trim, stock suspension. Its been since last year since it clunked, so I hafta wait till its gets cold again and I will remember it vividly. :D
Truck looks good, Scott! :D
Thanks Michael!
FYI this Bilstein set is for 2wd and 4wd and can be set at stock height, it does improve the ride...went through some potholes accidentally yesterday, and was suprised at the difference.
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
