Aluminum Block Benefits
I'm looking at an 08 Sierra Crew Cab to replace my 06. The one I'm probably going to buy has the 5.3 aluminum block engine. Other than weight, what are the advantages of the aluminum block or are there any?
Thanks, I already read that post. There didn't seem to be anything but conjecture.
There may be no benefit other than the light weight. Does anyone know what the weight difference is?
We love our conjecture here. Thats for sure :rolleyes:
Weight savings is about 100 pounds which will be offset by a heavier vehicle than your '06 was. The NBS trucks have added a little weight which I believe mainly went into a stronger frame.
Not sure if it's still the case but remember the hype from @ 5 or 6 years ago when GM introduced the aluminum 5.3L is it can meet emissions without Exhaust Gas Recirculation. It is also known these reach efficient operating temps much faster. So there is enough gain in thermal efficiency to effect emissions hardware & tuning choices that were known to have a negative impact on fuel economy.
Give it a few more years, you won't see cast iron blocks in cars or light trucks. Have an '08 Honda Civic with an all aluminum engine that is up to temp very fast. They even went as far as to directly incorporate the catalytic converter into the exhaust manifold. It works for Honda, gets both ULEV rating with great fuel economy.
Aluminum blocks will help getting to op temp faster. I noticed this on the switch from my SS to the Sierra. I believe it's a 70-80lbs difference between the blocks so not enough to really matter. GM uses camshaft design to get away from needing EGR setups. Less overlap negating the EGR valve. It really has nothing to do with the aluminum block.
EGR was deleted when DBW was introduced to all engines. The electronic throttle control allows the PCM to control the emissions by modulating the throttle during driving.
There is no real technical advantage to using aluminum. It is dimensionally less stable than cast iron when heated. In order to even be used as a block, strategic areas must be reinforced with steel. But - If designed properly it will last as long as any other construction material.
Aluminum is lighter and easier to cast and machine. These are probably the main reasons aluminum is used instead of iron in most cases. An assembled 5.3 aluminum block engine weighs 83 pounds less than the iron block version. That is a lot of weight savings in the car world.
The only benefit of AL for owners is weight. AL has many benefits from a manufacturing perspective though. It’s easier to work with, less expensive to machine, less expensive to ship, easier on tooling….etc. AL blocks were a down right pain in rear end to use until GM rolled out the GenIII small blocks. They completely redesigned the block to work with a new head design. I’ve built a few race engines where weight was a huge factor and I had no choice but to use AL. (410 sprint and light rail) When I was building them, Donovan was about the only game in town. They were grossly expensive, a nightmare to hone and line bore and almost impossible to keep the sleeves to stay put. I would have loved the opportunity to use one of the newer generation GM AL blocks. They’ve definitely eliminated a lot of, if not all of the little quirks associated with AL blocks.
Either 5.3 block material is completely acceptable from a dependability standpoint. It is nice that the aluminum block is lighter.
LOL!!!!!!!!!!!!!!!!!
Ask the Cadillac guys about those wonderful aluminum blocks with the stripped
out head bolt holes and the $3000 heli-coil fix in the N-star 4.6.
I wonder if time will tell and this issue will appear on the alum. 5.3s ???????
That does suck!
While that may be so on the Northstar, it's a design flaw and not a characteristic of aluminum. Many import vehicles have hundreds of thousands of miles on their 4 banger aluminum engines. Time will tell.
It does make me glad that mine is iron!
What I wonder is how all of these AFM engines are going to be after 150K. I'd bet there will be some big time expensive repairs there.
Boy...I remember those :thumbs:
Its been a few years since we've done one of those jobs at the garage.
    JimmyB4
    JimmyB4
  • Who's Online   0 Members, 0 Anonymous, 596 Guests (See full list)
    • Are you going to take long trips in it?  If so, try out the seats in the various trims. For me the lower trim level seats were not comfortable.
    • I have a 2016 that I bought new and still own. I'm around 129,000 miles now. The biggest problem was a transmission failure about 2 years ago around 95000 miles. No warning, just failed while driving down a back road. A reman GM transmission installed and it's been fine ever since. A few other minor problems along the way. I am in no hurry to replace it. It's been paid off long ago and do plan on driving this as long as I can.   I will admit I am leery about all the additional electronics in the newer models and feel that it is just more potential problems. I think there's actually more than I would have wanted in this 2016 but so far so good. I think even if something major like lifter failure happened, it would still be cheaper to at worst, drop a new engine in than buy a new vehicle.
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
