Another New One From Tx
OhOneW6
New to this board but not new the online car community. I don't know how I missed this board over the years. I've got an 07 Avalanche and a 72 Cheyenne Super in the stable now. The Av forum is pretty dead. I also have a 99 TransAm. I'm used to the traffic on the F-body boards. Looks like this place has traffic more like the car boards. I look forward to giving and getting help from you guys with the Avalanche mods.
Oh Yeah. The user name kinda stuck from my 01 WS6 TransAm that I traded a couple of years ago. Even though I don't have the car anymore I keep the name. ;)
Welcome Aboard, But on your Seat belt and enjoy the Ride!
His Avalanche is in his sig! And look behind you will Truck #2. Do your DL3's have Puddle Lights?? Welcome Aboard, Buckle up and enjoy the Ride!
http://www.gm-trucks.com/forums/index.php?...c=69943&hl=
LOL. [hind sight] If I'd only known about the puddle lights when I purchased my mirrors[/hind sight]
That pic is about a year old. Now there is a 30 X 32 shop where the 72 is in that pic. The truck and TA are in the building and what you can barely see in the left side of that pic is my 73 Sleekcraft Rebel Jet boat with a 400 Pontiac in it. The 72 truck needs a little work but with 400K on the clock the motor has never been out of it. it still runs OK but needs a restoration. Once it is complete it will make a nice period tow vehicle for the boat. LOL Man, I need to get these projects finished.
Looks like the Z in your sig is pretty nice. Do you post on any of the F-body boards?
Thanks for the warm welcome guys.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
