Greetings
Coalbunny
Hello ladies and gentlemen, I'm another new guy to the GM-Truck forum.
I recently purchased a 2001 GMC Sierra 1500 SLE with a 5.3 liter engine 4x4. I love it, it's very capable and in comparison to my previous truck, it's the cat's meow.
I currently reside in Leadville, Colorado around 10,200' elevation.
Thanks guys! Since I'm fairly new to the GMC crowd (had a '93 'Burban, but ditched it after the auto-tranny started bugging out on me), there's not much I can contribute. But I have been 4x4'ing for as long as I've been alive (screwed up my first car, like a typical kid). Now 39 and now I don't off road like I used to (did it for a few years as part of a few jobs I had).
Pics, eh? Ok, ya got pics-
Some of the country I work around-
A mug shots of myself at work-
Welcome aboard and nice pics!
What was the temp this am?
At my place, around -9*F, -12*F a few house down. Or thereabouts. I didn't write it down.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
