6" Bds Lift Questions
I am considering the 6" BDS High Clearance Lift for an 08 Sierra Z71, I just have a few questions about this lift systems. I see they offer 2 different 'rear method' kits: "block & add-a-leaf" and "leaf springs". What is the difference between these two methods? Im new to the lift world, just need some clarification/explanation. The truck is going to be used for a daily driver, rarely any type of off road driving. Which method is going to give me the best "ride". Are there any benefits/negatives of ea. system that I should be aware of? The $400 difference isn't a big concern to me. Also I see you can get the gas or hydraulic shocks, which one would be better suited for me, also what is the real difference between these two shocks? Should I be looking into a different type/brand of shock or are the BDS shocks good?
Any other info., opinions you can share with me are greatly appreciated. Just want to be sure of everything before I decide on this big purchase. Thanks
The new spring pack are springs that are longer and arched differently than stock springs giving the truck the lift. The new spring pack is the best way to go based on a 'performance' view point. You will experience less axle wrap but the ride might be harsher.
The lift block SHOULD replace your stock block but some companies tell you to stack blocks which is a big no-no. And the add-a-leaf is just another leaf that you place in your spring pack giving you about 1.5" of lift and should increase your payload capacity.
It's really up to you which way to go, but I'd definitely go with the new springs if you can afford them.
The block and add-a-leaf will make for a slightly stiffer ride, so if money doesn't matter, and you want a better ride, go with the springs. The block is a "block" of metal that sits between the axle and the leaf spring pack. There is one on the truck stock, but only a 1" block. The stock one comes out and will be replaced with a 5" block. The add-a-leaf adds the other inch to the back. Those #'s may not be exact as I do not have that kit, but that should explain it. The leaf spring is an entire new leaf spring pack. Your old ones will be taken out and these one's will be put in, giving you the lift b/c they are longer and arched more. They are the better all-around choice when it comes to ride and performance. Hydraulic shocks use a hydraulic fluid and a piston to absorb. The gas shocks contain oil and pressurized gas. There is obviously more to it, but the hydraulics will perform better and be slightly less stiff/smoother. The BDS brand shocks will be fine, especially since you do not plan on taking the truck off-road. All in all, you are looking into a great and proven kit. You will be very happy with your purchase.
Edit: Do you plan to do the install?
Sweet. Well let us know what you end up doing and post tons of PICS!!! Good luck with everything man, feel free to ask if you have any other questions!
The BDS kit is an excellent choice. I have the block w/ AAL with the standard shocks and I have no complaints. My truck is basically a street queen and it rides great, on and off road.
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
