Defrosting Windshield
Hello everyone, new to the Truck Forums. Just purchased a 08 GMC Sierra Crew Cab slt4 Duramax with all options available... I had previously owned my 03 gasser Silverado for 5 years and never had a complaint with it.
Finally I take the plunge for the Duramax, I decide to step up a notch in Creature Comforts and couldn't be more disapointed in the design of the windshield defroster..
Live in upstate NY with heavy snow and ice recently, and cant seem to get the entire windshield to defrost because the heat diffuser on the dash is directly in the center with no venting towards to the outside edges of the windshield. This allows the snow and ice to buildup and the wipers basically not to work because the snow and ice builds up on them... Has anyone else found this to be the case and if so, do you have you a fix for it or some way of improving this for better visibility out the windshield and less buildup on the wipers..
I can't say I have had DEFROST issues as you describe, but I will say this....
The stock wipers and the stalk design and resulting wiper design on this truck are NOT ideal. COmplaints of ice build up on the wipers is fairly frequent.
Many have gone with Trico Winter blades (your truly included), and it helps significantly. The 900 trucks don't have the traditional bayonett mount wipers, but rather a newer design (don't ask me why). Check carefully before buying replacement blade. I have found that many parts guides don't correctly list the replacement blades that we need, though they seem to be catching up little by little.
Do a search on wiper blades and you wil have plenty to read, and it has not been that long ago since those posts were floating near the top of the forum.
Hope this helps...
Check here for the Trico Winters: http://www.amsoil.com/StoreFront/trico_winter.aspx
Keep in mine that Diesels dont like to heat up in the winter like a gasser does so the heat coming out of the vents will not be real warm to defrost the windshield, are you running your grill cover? When its real cold out it takes a long time to get heat in the cab if you dont have a grill cover.
Cat got your tongue Harold? Welcome. :lol:
I was about to say the same thing
welcome
if u have ice on build up on your wipers u probably have ice build up on your outside vents just below the windshield. make sure they are clear of snow and ice or it will not defrost properly
Cat got your tongue Harold? Welcome. :thumbs:
Sorry, couldn't figure how to post reply.
Plow snow here in NH and have a terrible time with the windshield. I have opened a claim with the District Supervisor for GM, and was advised to work with my local dealer, who has no idea what to do. The service manager suggested covering the center portion of the defroster outlet to force air to the outside of the windshield! I am considering using a supplemental heater fan on the dash, and hope that somehow, someone will be able to come up with a solution to what is currently a dangerous design.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,220 Guests (See full list)
