Moraine Ohio Plant Closed Today
Saw on the local news today: The Moraine, Ohio, SUV plant had its last day of production today. VERY close to where I call home.
damn, I feel for those folks. Looks like it was a Envoy plant, from what i could see from the report.
They interviewed a guy that had been there almost 30 years. :jester:
I hate to see that.... what a crying shame.... This will hit Moraine pretty hard. :lol:
Dayton is a shitter anyways :jester:
WPAFB is the only thing keeping what there is around (if that makes since) between Cincy and Columbus.
I have to agree, and WPAFP is were I get my paycheck...
The Moraine plant has been a fixture of the local economy since it was a frigidaire plant back in the 60's. They did Truck and Bus, s10 trucks when they began production back in the 80's, s10 blazers and jimmy's, and were most recently building the Trailblazer, etc... line of SUV's.
It's very sad. By the way, I think it is Lorain, not Moraine, but then again, what do I know? :jester:
It's Moraine, Lorain is Northern Ohio and they have their own problems...
Talk about unfortunate :lol:
Well for one thing that means the '09 production run of the GMT-360 was an EXTREMELY short one....
Yep,The Trailblazer/Envoy's (GMT360) are done with now.
I also have a friend who works at WPAFB :jester:
This is a real shame. Unfortunately, most of us hear the headlines on the news about the various plant closings but it doesn't really sink in until it hits close to home or we know someone who is affected.
fawk, I forgot about the GMT360 ending in 2009, shit we are already midyear...has it been that long???
It's very sad. By the way, I think it is Lorain, not Moraine, but then again, what do I know? :lol:
I stand corrected. :D I think they closed the Lorain plant also. That is why I thought it was a typo.
Janesville, WI plant also closed yesterday.
What was made there?
Tahoes/Yukons
My Tahoe was built there Feb 08.
Dayton is a shitter anyways :crackup:
Maybe so... :D .... but the good folks that invested their lives in the Moraine plant aren't (not to be taken as what you were implying in any way, because I am sure you weren't implying it in that way)...
The military base I grew up around, and my dad was stationed at, was deactivated after over 40 years. I witnessed and experienced the base closing. A LOT of local civilians were employed there.
I'll admit it... I cried. That base provided me summer jobs, friends, my FIRST job (pushing carts in the commissary at age 7 :lol: ) . Ya really don't know what an impact something like that has on your life.
Again, Moraine, BAD situation, WORST time of year..... it just hits my heart somewhere where there's a similar memory.
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 885 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
