4.3l 15000 Cranks But Won't Start
Atheist
I know that it is a bit long but it reads easy and I am very stumped. I did include cliffs at the bottom. Please help!!
I purchased a single owner GMC Sierra with the 4.3L v6 about a month ago from a guy who had let it sit for 6 months prior to purchase. The truck was nearly spotless and ran great for the first two weeks which included a 700 mile road trip.
One day a few weeks after owning it I was driving and the truck just lost all power and slowly idled down to a shut off on me with only 380 miles on the tank. I have a long bed so I thought i had a 34 gallon tank and since I had measured my fuel economy on the first two tanks to be 18mpg I was very surprised at this. In any case, it would crank but not start so a buddy came down with some gas and it started right up afterwards. I assumed that was the issue and filled it up but to my amazement it took only 24 gallons total to get the truck back to full. I assumed I must somehow have the smaller tank and that the manual was wrong.
The next day I was driving down the road and it hesitated a bit then shut off in the same way a bit later. I had some tools with me so I pulled a plug to check for spark and sure enough I had a nice strong spark on a clean plug but the car would only crank and not start. I could hear the pump priming and fuel entering the rail. While I sat around thinking it over I tried cranking it again (10mins after it shut down originally) and it fired right up.
I noticed after that that the car had been hesitating and running poorly occasionally but running great at other times. However, one time I started my truck up, drove about a minute to jump someone who looked stuck, and the truck would not start again when I went to fire it up before connecting the jumper cables. It just cranked and cranked however I could always hear the pump priming each time I reset the key. I called a buddy to come and get me and while I waited I just cranked it for a while. After a while it wanted to start but was running around 300rpm and obviously very rough. My buddy came and got me and I went to the store and got some HEET. I added two bottles, shook the tank, and immediately went to start the truck. Fired up and ran great. However, I do not think it was the heat as it started first crank essentially and only a minute after I had added it.
I drove it another 600 miles in one trip and it ran great, no problems. Then one night i parked it and when I went out the next morning it wouldn't start. Odly enough, it had only been 12 hours where before I have let it sit in the cold UP for 3 days. I pulled it into the garage to tinker with it and threw a heater under it. I started by pulling the intake and spraying carb cleaner into the throttle body and it didnt even want to start. HOWEVER, I checked the same plug again and it was still sparking fine. All of the wires were plugged securely into the cap, too.
I pulled the fuel lines over the engine and primed the pump and a bunch of gas flowed however when I reconnected it, it still wouldnt start. I let it sit for the night (not a heated garage and no heat on it) and came back the next day and once again aftwer a bit of cranking it was running rough around 300rpm.
An hour later I went back out and cranked it a bit and it fired right up.
Cliff notes:
-4.3L V6 which sat for 6 months with a full tank
-Runs great sometimes, even up to 600+ miles continuously
-Will occasionally hesitate/lack power
-Occasionally shuts off while running or will fail to start after being shut off
-Typically, after a while of cranking it will run at 300rpm. Then after a while later of sitting it will start right up and run fine
-Fuel pump PRIMES every time, fuel does spray out of the rail. Pressure unknown
-Confirmed spark at the plug
-DID in fact start on start fluid.
UPDATE ONE:
Checked the fuel pressure - came back at 60psi during priming. Pulled the cap -- it and the rotor looked fine. Going to go have the coil tested at `THE ZONE`.
UPDATE TWO:
We sprayed starter fluid instead of carb cleaner into the TB and it started to try to run so it is in fact working to that extent. New coil did not change anything. Fuel pressure is a constant ~61psi during priming and cranking. It does spark.
I do not know if the injectors are firing. If they are, I think it is probably bad gas sediment even though I have put several tanks in. Or some issue with the TBI that I do not know about. Who knows about TBI???
I'm stumped! Here are my thoughts on parts it may be:
Fuel pump:
Fuel pump checks out at 62psi.
Something else:
??? I have a lot of experience with cars but I am new to the GM/Truck world. What else could it be???
THANK YOU!
Pull the distributor cap and look at it. I bet it has white chalky corrosion in it. My 01 4.3 did a very similar thing. Turned out that it was water dripping off of an ac line that runs across the top of the distributor. Over time the moisture corrodes the inside of the cap and the truck will run like crap. stall, or simply not start. You'd still get spark at a plug... but it is enough to make it have problems. Mine was towed twice and the dealer added insulation and covered the AC line the second time and it never did it again in 60K miles. (there was a service bulletin out on it)
Replace the distributor cap and see if that fixes it. If so, insulate the AC line and redirect the condensation to drip somewhere away from the distributor.
:lol: It could possibly be a crank/camshaft sensor. jmo
Can someone help me find a reason that the car wouldnt start even with carb cleaner???
If the cap is all corroded, it may fire but at the wrong times. Have you pulled the cap?
Any other ideas???
When you're cranking it over and it won't start have you noticed any of the gauges jumping around? This indicates a PCM problem.
Negative, they are all good.
You could have someone try to start it while your listening to the injectors with a stethoscope. You should hear them clicking. Someone mentioned crank sensor. I don't know if a failed sensor would still give a spark at all or spark at the wrong time. These newer vehicles can be a real pita. I'm having starting trouble also but only when it's real cold. Mechanic said it was the fuel pump so he changed it and $850 later it still won't start. You're better of changing parts yourself rather than paying someone else to do the same thing. Sure, once in a while you'll change the wrong thing, like a coil, but in the long run I think it saves money and you learn more to boot.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
