  • Replies 33
Top Posters In This Topic
I used to have a 76 with the Royal Sierra badges on it (on the dash) and the fenders had Sierra Grande on them, although I am not sure what was original or not at its age.
one of the last pics before I sold it 4 years ago
I think its the GMC version of the chevy bonanza trim pack. Theyre probably as rare as the 454 GMC street coupes.
they had a lot of limited run packages like that. GMC STREET COUPE
heres the website
http://gmcspecialeditions.com/index.html
I wonder how rare the current GMT900 Sierra All-Terrain will be by comparison... I know I have never once seen another one aside from mine around the area here....
After I ordered my all terrain from my dealer he liked it so much thats mostly what he stocks now...although most of what he gets is the crew cab version. So I see quite a few of the All terrain pkg Sierras running around . So far my pickup is the only red extended cab around here....As for how rare they might become who knows, I guess that depends on the future of GM also.
Edited by TheWaterboy
True; I'm sure it does depend on the area too. Either way, mine is also a bit odd for an All-Terrain as well -- it's a Crew Cab, but it doesn't have the two-tone leather seats, mine are solid Ebony. :lol:
True; I'm sure it does depend on the area too. Either way, mine is also a bit odd for an All-Terrain as well -- it's a Crew Cab, but it doesn't have the two-tone leather seats, mine are solid Ebony. :)
this is a bit off topic but how do you like your "all terrain" so far??
    • 3.19 @ Kroger’s in Montgomery Tx
    • We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
