Touchless Broke My Bug Deflector!
punmax
So I got my truck washed yesterday and at the end where the fans blow huge amounts of air onto your truck to dry it, my bug deflector broke in half :lol:
I took the deflector off and found the clips that held it, took paint off of my hood.
Should I just go get touch up paint? And does anybody know the part # for this accessory?
Thats one of the reasons I don't go through car washes. Cold temps on plastic, suddenly being exposed to warmer ait, and the force of those blowers will crack some defelectors. I had two crack on me before, the owner of the car wash repalced both of them, even though he had a sign saying he wasn't responsible for any damage. He also has an oil change business and I brought him alot of business, so he treated his customers right.
These deflectors will break more less during winter time cause of the temps, so keep that in mind next time you venture off to a car wash.
You sure he wasn't just afraid of you? :lol:
You sure he wasn't just afraid of you? :thumbs:
:lol:
A couple of years back I was at a local touch-less car wash, and was behind a guy in a Chevy dually...well as you can probably guess when it got back to the rear quarters it hit the passenger side fender and punched a huge hole in the fiberglass.. and proceeded to get stuck on the fender, so he had to pull away and tore the fender off. talk about an expensive car wash! :lol:
sorry to go off topic but seeing this thread made me think of that. :thumbs:
im going through the car wash tonight since i drop my truck off at the body shop 2 marro and dont want to leave it dirty as hell im going to wash it inside and out..
i find it ALOT easier to work on a truck when its clean.. at least i know at work i do..
Wash it with your own two hands or GTFO.
+1... That way if anything breaks you know it was your fault and that you werent just being careless and stupid!
That's easy for someone in Texas to say in January. :thumbs:
It sure is. :lol:
Move somewhere warmer or GTFO.
It sure is. :lol:
Can I have a bucket with a torpedo heater and a garage for less than $15 please... :D
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
