Stereo Won't Give My Cd Back
My 2004 Silverado has the CD/Cassette/AM/FM stereo radio in it and just recently refuses to eject the CD. All I hear is a clicking sound coming from the unit. I suspect there is some small plastic part/gear broken.
Any comments on what I might do to fix this problem? I imagine getting the unit repaired is costly.
Thanks for any help.
Does it come out just a little bit then goes back in? Or does it not show itself at all? If it comes out a little bit, you can take a knife or something and push down on the top when you try to eject it, and it should come out.
No, it doesn't show itself at all, the unit just clicks for about 15 seconds then displays "check CD".
OK, so if I buy a used deck at a salvage yard or off Ebay, is there anything special I will have to know or do?
i wouldn't think there is anything special you would have to do.. i haven't messed with car stereos too much since my high school years but if you get a factory radio just like the one in your dash, it should have a wiring harnes you can unplug and just plug the new one into. install it and put the dash back together.
What about the theft protection? Some vendors on Ebay say it has to be programmed to the truck with a TechII scanner. What's that all about?
i would be lying if i told you i knew anything about that either. wish i could help you but i haven't had the oportunity to work on one of those. the closest thing i could tell you is that i have a 97 lumina with theftlock on it and once it got locked up and i didn't know the code... i bought the instructions to change the code off of ebay for 5 bucks and it's been ok ever since.
that prob doesn't have anything to do with your situation though.
I've had that once, very annoying. I managed to eject the cd by prying a piece of thin carton in the opening and wiggling it while pushing the eject button. The extra pressure made it pop out. Be carefull though, you don't want to damage the insides.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
