would idle speed valve throw code? is the sensor plug and play?
This is the 3rd thread you have asked about this. If by "plug and play" you mean, can you just install it and forget it then, yes. OBD1 was fairly generic in that aspect.
Is there a check engine light on now?
Do you have a code scanner?
Have you searched the internet about this problem you are having? What is the problem? Have you run compression tests on all cylinders? (this engine is tired at 200K).
What are your leak down test results?
Are the injectors original?
How much crankcase pressure does the engine have?
I see in the other threads that you have 200K on this truck. Perhaps it is time to start "throwing parts at it", but you should do some other research as well.
COMPRESSION 150, NEW PISTONS RINGS, NEW CAMELBACK HEADS, NEW VALVES, ROLLER ROCKERS, NEW CAM, NEW LIFTERS, NEW EGR, NOT THE STOCK ENGINE EITHER CAME WITH 305, NEW ENGINE HAS 150,000 ON IT. i REPLACED THE TPS NOTHING, CLEANED THROTTLE BODY NOTHING, NEW FUEL INJECTORS NOTHING, JUST WONDERING IF IT COULD BE IDLE CONTROL VALVE BUT NOT THROW A CODE? AND IF IT WAS COULD IT IDLE FINE BUT BOG DOWN AT STOPS AND IN PARKING LOTS AND ALMOST STALL BUT NEVER DOES. AND SORRY ABOUT THE SEVERAL POST BUT IT SEEMS LIKE ONCE IT GETS OFF THE FIRST PAGE NO ONE READS IT AND THIS IS AN EVERYDAY DRIVER AND NEED TO FIX IT. ALSO CHECKED CODES WITH PAPER CLIP FLASHED NOTHING!!! THANKS CODY
No need to yell, chief.
What is the fuel pressure? Did you cam the engine when you built it, and if so, what is the manifold vaccuum now?
LOL IM NOT YELLING BUT HOW DO I CHECK MANIFOLD VACCUUM? AND YES WHEN I BOUGHT IT THEY CAMMED IT NOT SURE WHAT THEY PUT IN IT BUT ITS A FLAT TAPPET CAM. WHAT WOULD MANIFOLD VACUUM TELL ME? COULD THIS BE IDLE CONTROL VALVE?
Just put idle control valve in today and i still have the same problem!!! :crackup: Its not throwing any codes i checked. what could this be ive been throwing parts at it and its getting expensive. Would sea foam help? If so where should i put it?(in tank, top of TBI, pcv valve) Any help is greatly appreciated!!! CODY
New to this thread but will make a few comments.
You do not need to re post the message to keep it on the top page. Just reply to it with "bump" this will keep the original message and replys all in one place so people can read all the comments made and not be redundant.
You have so many modifications - heads, injectors, cam, not to mention even a different size engine. Have you altered the computor to compensate for all this? I am sure your present setup has different requirements and is sending different sensor readings than a stock CPU is programed for.
Bogging on acceleration sounds like timing advance isssues.
Stalling at idle could just be idle speed issues.
Sea foam though the PCV valve, but this does not sound like a fuel system problem. If this was just rebuild it should not be dirty enough that you would need sea foam.
The rebuilt engine has 100k on it and it just developed this problem..... Let me reveiw this problem when i come to a stop or am in a parking lot it acts like it wants to stall but it doesent upon acceleration it is fine runs great. Here is a list of things i did after it developed this problem, TPS, EGR, cleaned TPI, new fuel injectors, resurfaced heads and put new valves,springs, and rockers, Idle control valve, new cattylic convertor, plugs wires, rotors, distributor, checked timing, good compression, checked MAP sensor, good PCV valve........ THe only things that i can think of that i havent checked are vehicle speed sensor, vacuum, and ignition. Is there a way to check vacuum and how do i check ignition I am sick of throwing parts at it i need your guys help on this one its getting expensive and its still a solid truck. Even though im spending all this money its still cheaper then a car payment. :D Any help is greatly appreciated!!!! Thanks CODY
like mentioned before I would check the timing, does it start real easy or seem like it has a dead battery and might not start?
starts sorta hard but its cold and when i redid the heads i set the timing to factory 0 degrees and it still did it this has been going on for awhile could it be cracked fuel lines the lines are stock? new fuel pressure regulator today still nothing. how do i check my fuel pressure? thanks CODY
What is the timing supposed to be, I could be wrong on this but with all of the aftermarket parts and the cam I would think that setting it at 0 degrees would be a start but needs fined tuned. I have seen them when they are just a little off that they seem to run right but then want to stall, and the hard starting makes me think that it is off a little that is why it seems hard to start, just my opinion.
that could be but the timing was set at o degrees for two years and ran fine until recently how do you check your vacuum i think it could be that or maybe a cracked fuel line. i need to fix this thank you
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
