Nbs Doors A Creakin....
any of you with the NBS Extended Cabs have doors that basically just make a just enough to piss you off noise when you go over bumps in the road, or parking lots, etc??? I know that its probably going to make a little noise being that there is the lack of a post between the doors, but is there anything that can be done to fix this.....I'm finding it more and more annoying as the truck gets more miles on it....it has done it since new, but now at 33K miles it has gotten more noticeable.
I don't have any rattles between the doors, but I do have some creaks inside the armrest of the driver's door. I think that's just some loose sound-deadening material that needs to be tacked down.
In response to your question, check and make sure that the latch at the top of the suicide door is fully engaged. I've found that if the door doesn't close hard enough the top one won't latch. That could cause a little sound.
I heard of some sort of grease or tape. :D
I've heard that also...thought I saw it on here like there was a Service Bulliten or something....
My doors creak like an old hooker's knees... it drives me up the wall. There are speed bumps in the parking lot where I work (like anyone's in THAT much a hurry to get to work) and going over those even at a crawl elicits all kinds of creaking from both driver and passenger sides.
Interestingly enough, on damp mornings or when there's even just a little drizzle, they're silent.
This is the first extended cab truck i've owned (previous trucks were RCSB). I've been annoyed by the doors from day one. Not only do they creak/squeak when goin over bumps, they also whistle in a good crosswind. I've had the dealer adjust them twice. Lesson learned. The next truck will be a RCSB.
My driver's seat belt assembly pops. Actually it pops up where it connects to the door and sometimes the piece by the center console pops. One of these days it'll piss me off enough that I'll pull those 2 things apart and lube, tape, weld, whatever I need to do to shut them up.
Plus I need to see about the driver's window noise when rolling down when cold/damp, I hear there's a TSB for that.
Mine make noise, no whistling though. I guess I've gotten used to them because I don't seem to notice it anymore. Maybe I'm just listening to music louder? Still love my truck and think everything feels very solid, just not as solid as my dad's crew cab.
I have some sqeeking of the door seals, but have drenched them in silicone lube and they're mostly quiet now. I too have the popping in the seatbelt harness thing...really strange!
The other door noise I've noticed recently in really cold weather, is a loud creaking from the hinges on both drivers and passenger when opening them. It really makes me wonder how junky this truck is going to sound in 5 years? 10 years? Oh well, the wheels will probably have long since fallen off by that time! :D
I've had the whistling sound like the weatherstripping isn't all the way on there. It only happens when I'm on the freeway. Annoying too. :D
I have the crew cab, and the driver's door seems to squeak quite a bit also, sounds a little like there is a wiring harness loose in there it is so faint. When I pull out of my driveway over the drainage ditch is makes the most noise, as the body is flexing. The dealer ship cannot recreate the noise, huh, who would have thunk it?? Taking it in for an oil change this week, will take the service manager for a ride to show him. Will let you know what they come up with.
WOO HOO!
RCSB FTMFW!
this was an pretty common issue on the 2000-2007 old body ext cabs. Seal noise due to body flexing. If it's the same thing just get some "silicone spray Lube" and coat the seals every few months and the creaking should be gone for good.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
