Warranty Work
I had the truck in today for a few things. Squeak when its cold and wet out. for 2 new belts for the cold start squeak. New bug shield to replace the warped one. Muffler vibration. And the seats with all the lint on them. They put some installation around the radiator to try to fix the front end squeak. They put a band around the muffler shield. They put a new bug shield on there and cracked it,putting it on. they ordered all new SEAT COVERS for it. It may take 4-6 weeks for them. I told them I doubt the installation by the radiator would fix the squeak. They couldn't hear it.I get the truck and take off around the parking lot and its squeaking. I came back around and picked the service guy up and he can hear it and then the mechanic drove it and could hear it. So now its going back Monday night so they can have it all day on Tuesday to see if they can fix it.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
