07+ Gmc Sierra Tinted Tails
Lifted_GMC
07+ Sierra Tinted Tails
$250
you got some pics of them lighted up??? local laws little ruff around here if they not look red when on.
also you have the bumpers painted? what that cost, i love for black bumpers.
But where are the black wheels?! :D
Hopefully there are some powerful red LEDs in there to make the lights show up well.
Hey thanks for your thoughts. The tails are perfectly legal and visible.
"and which shall be plainly visible and understandable from a distance of 100 feet to the rear during normal sunlight and at night."
Now if you're not interested in buying them you can kindly gtfo.
Sounds like somebody might be a lil testy.
not really, this is a for sale thread not a thread asking for comments, thoughts, and opinions. seems like a simple enough concept to me.
Yeah but this is also a FORUM, and thats what we do. If you only wanted sales go to e-bay, DUH!!!!!!!!!!!!!!!!!
Some people just need to get a sense of humor beat :D into them.
[/u][/i][/b]Some people just need to get a sense of humor beat :D into them.
thanks captain obvious but thats what all the "discussion" sections are for. and some people just need some sense beat into them. can already tell that this is a lost cause. :cheers:
And some people have questions about the product that they may or may not buy. Plus, I dont know many people that dont like comments about their truck, or opinions on things that they might not have otherwise considered. So get off ur high horse,and in ur case get under it and SUCK IT.
AND IM DONE
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
