Hey everybody,
First time here. I'm looking for info on tunes for a 08 vortec max. I've found very little on it. From what i have found, its not a lot. Has anyone had theres done? what was done? and are you happy with it? You help would be greatly appreciated.
Thanks,
Hey everybody,
Thanks,
Ton of information on this site about it. I have a 07 that is the exact same as your 08. I had a custom tune with Justin from Blackbear Performance.
I think you will find 99% of the people here are going to recommend a custom tune. And 99% of those will probably recommend Blackbear.
www.blackbearperformance.com
Lots and lots of people on here have a custom tune on a Vmax. :) Check out the site sponsors Blackbear Performance and Wheatley Performance Tuning, they both do tunes for the VMax.
By all reports your truck will be a new truck after a tune. :lol:
Also depending on where you live there might be an upcoming live tuning meet with Blackbear.
+1 on Wheatley and Blackbear. Both great tuners.
Otherwise, if you want a handheld, the Diablo Predator is by far the best.
+1 More on that. I forgot about Wheatley being a new site sponser. If you decide not to go custom Diablo is the only route to go.
