Both Xm And Onstar Not Working
i just brought an used truck and i find out that both onstar and xm is not working!
when i try onstar it said push again for a demonstration when i do so all i can hear is an bip bip bip....
on xm all it does say it's no signal and i got i activated today but i won't work!
i have an 2006 GMC sierra slt
i have checked connection on the antena and in the glove box everything look fine!
i took some pic of the antenna wire i found 2 unconnected wire with some wire that look like the onstar microphone's!
some wire in the back of the glovebox that look okay
another box with wire that look okay
did you see that green connector? it is also a antenna connector well it look like and it is unplug!?
Hey there and welcome to GM Trucks! :uhoh:
Odd problem. It kind of looks like the previous own had customizations to the audio system that he took out before selling and and didn't put the stock components back together correctly.
yes :uhoh: this is not funny since my xm is active right now and can't listen!
hi i didn't take time to introduce me since i was disassembling my truck in my court yard! next week i will look further on that at my work in the garage! here it is still -10 so not fun to work out side yet!
here is what my truck look like! i now have added a hood deflector and 4 mud flap but don't have taken picture of that since i have done it yesterday
Did you buy it from a dealer or privately. If you bought it from a dealer I would be going back to them to fix it. If you bought it privately I'd be going back to them to find out what they did to it.
If you know electronics, then I would suggest getting a factory wiring diagram and start troubleshooting. However, with cabling in a vehicle and possible missing cables, things disconnected, this can be quite difficult and time consuming even for someone who knows electronics! This is one of the most difficult problems to troubleshoot because things are not as they should be and there are multiple problems.
The easiest and quickest thing to do would be to compare your trucks connections with another truck of the same year and model. Then reconnect everything the same. Then troubleshoot from there if something is still not working.
With that said, taking your truck to the dealer might be the best thing because they would have similar models there and could peek and see how things are connected on another truck.
If it was an older truck, I would suggest going to a wrecking yard and taking pictures of the connections on a similar truck. But I doubt you would find this truck. Might call around and see if a wrecking yard has one.
well im a diesel mechanics so im some what familliar with troubleshooting and electrical trouble and i will look further on this trouble one of these day when i got time!
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
