Truck Wont Start
Well tonight after dinner my truck wouldn't start. Seems to have plenty of power. Everything lights up. It just won't start.
I'm assuming its the starter. There were no signs of it going bad. Is there a solenoid that might be bad, or do I need to replace the whole starter? Anyone no how much one of those runs for an 02 5.3 silverado? Also anyone know what tools I will need to get it off. It's park in front of the local pizza joint. I just don't want to go back and forth with the wrong tools.
Also if there are any other suggestions what it may be, please help.
This may sound silly but turn the key on, step on the brake, and pull the shifter down in Neutral. It is not too uncommon for the Neutral safety switch to go bad on these trucks. If it is in fact a starter the old standby trick is to get under the truck and tap it with a hammer while somebody tries to start it. If the solenoid is stuck, the tapping can dislodge it. It's a temporary fix but it might get you home.
Good luck man!
First check should be for voltage. You'll damage a GM starter if you try to crank it with less than like 9.6 volts. Check the battery voltage without trying to crank, then check as someone turns the key. If you have correct voltage when someone is turning the key then look to the starter, starter relay, or ignition switch. I don'tg know what color the lead is on the full size truck starters but with key off you should have no voltage at the solenoid and with key in crank position you should see 12v.
If you see voltage at that wire (smaller of the two as larger one is the battery cable) then it's most likely the starter is dead. If no voltage then trace the wire back to the relay (not sure where they put them on our trucks as I am going off memory for a Blazer) and see if you are getting 12v coming out of the relay. a multimeter is your friend in cases like this.
Also, have you ever replaced that specific starter before? GM doesn't like to put a lot of spare cable to the starters and when you try to pul one down you tend to have to bend the ring terminal that goes to the starter solenoid. When you bend it back you weaken it and it could break. This happened to me and my wife was stuck in a WM parking lot. I was able to pull it home and after thinking I got a bad replacement starter, I only needed to replace a $.40 connector.
Put it in NEUTRAL and try to start it.
It may be the neutral safety switch.
It's probably your starter. It is giving you the first signs that it is going bad. If it is the OEM starter, it is definitely time to get it replaced. I'd personally change it now, instead of getting stuck somewhere with a dead truck. Good luck.
Well this morning it started several times like nothing was wrong. Only thing different was that it is damp outside. Any ideas ?
When it wouldn't start before was it when the engine was hot? That's an age long problem for GM vehicles. The solenoid gets too hot and won't kick work. That could explain why it started when cooled off and damp.
Odd problem for sure.
My daughter's Blazer is doing the same thing. She doesn't believe me. :seeya:
Well we had driven for about 30 min around town. It was around 9 at night with the temp around 45. Stopped and ate pizza for 20 min, then went outside and it wouldn't start. So I would think it would not of been to hot, but who knows.
Also is there some kind of security issue maybe with the keyless entry. I know last night I locked it with the key fob before the wife opened the door, and she had to unlock it. Then I locked it again before she had finished closing her door with the key fob.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
