What's Up With These Mirrors?
This is a truck that I am looking at. The ad says it is a 2007 LTZ, but I have not seen these mirrors before. Are they something the previous owner installed or was it an option?
Those look like the optional towing mirrors...
Ahhhh, so there probably is quite a bit of towing miles of the 18k on the clock.
Thanks!
I had my stock mirrors replaced with those kind for towing. They are a nice mirror even if you are not towing. They have the signal light in them, and they are heated. They are about $500.00 to get done.
well, also, keep in mind, that unless you live in TN, they will be a general hassle not just for you, but to other drivers. here in WA, suckers are, basically, sticking out of the lane width. not to mention parking lots, underground garages, and all of them nice concrete posts on turns in them.
As everybody has stated they appear to be the GM towing mirrors, That does not mean there are towing miles on the truck. My truck is 8 or so months never towed anything yet.
I have the towing mirrors on my truck for 3 reasons 1 I will tow with my truck so need the increased vision provided, 2 I drive fire trucks/ambulances with that similar style of mirror and prefer them to the other factory style 3 I can see better in the towing style mirrors
I made it one of the search options when my dealer was looking for my truck.
If you have never driven with that style of mirror it will take some getting used to, but try it you just might like them. :lol:
I drive on narrow rural roads every day and have never had a problem with the width of the mirrors. Note to self if the mirrors do not clear the obstacle then the rest of the truck, car will not clear so good to find out early before the damage gets really expensive.
We calls 'em Dumbo ears :lol:
As far as they stick out, I'd be losing one a week... the way I drive. :lol:
Put some on the Z, Jim!!! :D
My truck came with those mirrors. Besides sticking out like Dumbo ears :lol: , I couldn't see that well through the passenger mirror. It was a magnified mirror, :lol: and that created a serious blind spot for me, no matter how well I adjusted it. So I replaced them with the standard mirrors.
Those towing mirrors are like most other accessories...some people will like them, others will hate them.
It's really up to you.
Personally, I really like them! If you're going to tow in the future, I would keep them.
    • Oh yes, someone is going to be certainly hitting up GM service/ support for a 20 year old truck.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
