New-to-me Truck
Hey guys, new guy here... skipping the intro forum, headed straight here. I'm stoked about my new truck. Picked it up a week ago. Got a SMOKIN deal on this thing.
Dad has had a Chevy for as long as I can remember. I've always wanted one, but could never justify a full size truck. I've had dozens and dozens of other rigs, and I can't ever remember being as satisfied as I am in this thing going down the road.
Mileage has always been a concern for my daily driver, but now that my commute is 3 miles long, with only two stops signs, I think I will be okay :nonod:
Here it is. It's got some miles on it, but you'd never know by looking at it or driving it. The engine bay is spotless. One owner before me, spent it's life in a non salt road area, obviously garage kept.
I'm in the process of working out a few small issues that it has. It's got the 4x4 switch issue, and it's currently giving me a solid service engine light. Need to go find the code to see what it is.
It's got a nail in the right rear tire, but holds air for a couple days (low in the pic obviously).
Cool forum, and thanks guys.
Welcome to the forum, you will find it extremely helpful. Nice looking truck, it appears to be very clean. Enjoy
Welcome to
Nice truck...looks real clean. And the jeep looks cool too.
Thanks guys.
I also changed the battery already. That was the factory one still in there :nonod:
I'm getting a bit of metal rattle sound from out back when I hit a certain RPM. Seems to happen worse when it's cold. I think it might be exhaust. Gonna have to see if something is loose under there.
Good looking truck! Looks just like my '01 did... That color is perfect for always looking clean!
Your rattle is probably an exhaust shield that is loose.
Looks like a nice clean truck. New or old, there isn't anything like getting a new truck! :nonod:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
