Newbie To The Site, Not To Gm's
Hey guys and girls. I just sold my pride and joy unfortunately. I built a 1987 Chevy K10 Stepside from the frame up and made a show truck out of it. Completed the project in the end of the summer of 2000 and had less than 3000 miles on it when i sold it last week. The truck never saw snow, rain, fall (nuts coming off the trees), winter or even early spring. Friends always made fun of me because the 36" swampers never saw mud. Had to let the truck go because we just bought our first house and could not justify it. Now it's time to do something with my 2004 GMC 2500 regular cab with the 8.1. I will be searching for as much info as possible on the lifts for these style trucks. Looking to go between 8-10", nothing to crazy. If anyone has any input, please let me know. 73-87's i have down pat, but the new suspensions i have not tinkered with yet.
PICS, NOW!!!!
and...
Welcome! :cool:
Welcome.
Nice job on the restoration. What color paint is that???
Based on the pics and his screen name, I am going to go out on a limb here and say......
Red. :cool:
The color name is passion red. It was the factory color for the 1997 Mitsubishi 3000GT's. It actually turns a tint of orange-red in the sun. That was a wild color. I miss the truck already and it has been less than 1 week
red87chevy,
California Super Trucks (CST) is one of the few manufacturers who's lift does not drastically alter the CV angle. They havea 8or 10 inch lift, as well.
good luck,
Richard
Great looking truck and welcome to the site man! Good luck with the search on the lift-kit there is a ton of information on here!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
