Electrical Problem Or Fuel Pump Bad, Is There A Test...?
chatvmax
Electrical problem or Fuel Pump Bad,, Is there a test...??
1992 GMC Van V8 Two Wheel Drive Automatic 99,000 miles
I have a 1992 GMC 5.7 ltr V8 with 99,00 miles on her,, She always ran good and is well kept:
Issue: No fuel to throttle body:
Van was running great about a week ago, I parked her and came out yesterday to go somewhere,, She cranked but didnt even pop..
When I took the air cleaner off and put a little gas down the throat of the throttle body she starts and runs till the gas runs out,,
1: Checked Fuel Pump Fuse,, GOOD
2: Put a meter on one side of the fuel pump fuse socket and 12v is there,
3: replaced fuse JUST BECAUSE
also replaced the fuel pump relay...
When I unpluged the fuel pump wiring connector back at the tank and put a meter on the plogs,, between the black wire and the grey wire i get 8.6 gvolts comming from the van harness,, the battery is fully charged..
4: i put 5 gallons of gas in the tank and looked for leaks NONE
5: Disconnected the 2 fuel lines that go to the throttle body,, NO GAS comming out - ZERO, disconnect the fuel line Before the fuel filter and NO GAS,,
6: Important note: when I turn the ignition on the dash board fuel gague goes way past full till it hits some sort of stop,, then when
I turn ignition off the fuel gague comes back to about the full mark,,? ther fuel gague always worked before ..
NO rust or leaks looking from the bottom,, but the van is parked in the gas and really cant jack her up or anything::: when i rap on the bottom of tank there is plenty of gas in it... HELP !!
[email protected]
shouldnt there be 12v a that connector back at the fuel pump..?
again gas in tank, starts and runs if i poor gas into the motor and then dies,
NO gas comming out of the fuel lines to the throttle body,,
Isnt there a Ohm test I can perform on the fuel pump..? Or can I just connect a ground to the black wire going to the fuel pump and hit the grey wire with 12V from the battery to see if it pumps gas...?
Being as all vehicles seem to be differently designed any chance they get to do so, and being the dangerous nature of this repair...
I would suggest going by the factory repair manual on this one.
With other vehicles I've worked on, the fuel pump does not turn on until the ignition is switched to start or the engine is running. Just ignition on will not power the pump. (I don't know about your specific vehicle.)
Then there were specific steps to take in the factory service manual for troubleshooting this... Do such and so steps THEN jump these two wires at such and so connector, then see if pump starts up, etc.
As to the fuel gauge, many times this is a part of the electric fuel pump. So a clue there. Does the gauge peg the meter with the fuel pump connector disconnected? If no, then probably fuel pump problem, but best to verify this with the shop manual. (Usually these would read nothing when disconnected, but I wouldn't be surprised if there are vehicles out there where it pegs with the lines open or disconnected!)
Ok,, I didnt get a manual,, I tried but couldnt find one local,,,,
and I followed all the fuel pump wires and cant seem to find any issues,,,
I did recheck the voltage on the 3 wire harness coming out of the tank there is zero ohms between the black wire and frame or chassie ,, so it is the ground,,
The center wire [ grey ] has 8.6 volts comming down from the harness side..? no idea why , i would think it would need 12 v... BUT i did keep the gas line OFF between the fuel pump to fuel filter so i didnt damage the pump if something was cloging the line and it did happen to pump gas,, and then i :
.. Ran a wire from the black wire going to the pump and ground,,
THEN i hooked 12v+ to the grey wire [ center ] wire going to the fuel pump and NOTHING,, no click, no gas pumping,, not a noise,,,..
Looks like pump is bad,, NO...???
so to be clear i disconnected the gas line between the pump and the fuel filter and grounded the black wire off the pump harness, and connected 12v+ to the center wire comming off the pump harness and NOT A CLICK or peep.. or gas.... ..
Im going to get a pump tomorrow,,, I drained all the gas i could get out of the tank tonight and hit all the strap bolts with penetrating oil..
sound like i am progressing in somewhat the right direction?
[ I understand that you cant give me a green light cause of "gas tank" work and its dangerous stuff,,, but how does it sound as a reality check in general...??
Thanks for taking the time to respond....
It would be a blessing to have a schmatic of this pump or the new pump.. i am a electronics tech,, not a mechanic :thumbs:
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
