Dinalli Whels On A 06 2wd Offroad
I found a pretty good deal on a set of the Chrome Denalli wheels for sale, would they fit and look good (proper offset) on my sons 2006 Canyon 2wd with the Offroad Package (Torsion Bars)?
100_0897Small.jpg[/img]
IIRC the lug pattern is different
I'm not sure about the offset, but the colorado, canyons and the hummer H3's all have the same lug pattern as the full size trucks and Suv's. The Trailblazers and Envoys are a totally different lug pattern(even though they are still 6 lug). I would check a lil more into the backspacing to make sure, the lug pattern is the same.
  • 2 months later...
The lug pattern is the same and they will fit. The center bore on the Denali wheels is smaller though so they will have to be bored out. The only other thing you need to check is tire clearances with those tires. There are several Colorado's running around with SilveradoSS wheels.
yes the center bore of the rims are bigger on the canyon/colorado's. So you will have to run spacers or get the centerbore machined bigger.
