Need Help With Step Bar Part #'s
Well I finally found a good deal on some Step Bars and I need to verify if they will work on my truck. These Bars are GM Part #'s 19155391 and 19155392 and came off a 06 Silverado Crew Cab. I need to know if they will work for a 07 NBS Silverado Crew Cab. I've tried several GM part lookups but it's showing that the part # has changed or isn't available. I'm wanting to go pick them up today, but I'll have to wait to see if they will fit before I make the 3 hr drive. thanks,B
Edit: NM. I have no idea. :)
i was counting on you to buzz in with your GM "smarts".now you let me down.. :P I think they may work based on the pic of them, but I may be making a trip for nothing.. i hate to assume.
As far as I know they will NOT work,The GMT800 steps bolted to the body mounts,The GMT900 steps bolt to the bottom of the rockers.
Of course only way to know for sure is to see if they will bolt up to the body mounts on your truck.
That's pretty much what I typed in my 1st post. Then I realized he is trying to put GMT800 steps on a GMT900, and I do not know if the body mount locations changed?
