Poser?
chev1guy
If this has been posted before i could not find anything.
Should a 2wd truck be lifted? I want to lift mine but thought about it and felt i would lool like a poser if i did.
dont be hatin on 2wd man. mom didnt want to pay extra for 4wd...
and no dude it dont matter. nobody will know if ur truck is 2wd or 4wd unless they know about trucks or they ask you and you tell them...
im planning on getting a rancho quicklift or a rancho 4" lift sometime... when i have money.
not hatin my truck is a 2wd drive. The 4'' lift from Rancho was my original pick but after considering it was a 2wd i decided to go for the quicklift too. Hoping to get it done within the next month.
NICE DUDE!!!!! Take some before and after pics for me PLEASE I am not sure which one I want. Tell me how you like it and everything! make sure you make a new thread after you get it installed and stuff!! Are u getting new tires and wheels?
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
