Lifting Truck To Do Work
What can I use to lift the rear of my truck so I can do some exhaust work in my driveway? There are some old metal ramps out in the shed, but I think they are for small cars, do you think those would hold it (and do you know what I'm talking about lol)?
i lift the front end of my truck with ramps that are just a little bit smaller than my tires alot. The ramps hold up just fine. SInce the rear end is a lot lighter in weight i bet they will hold. Don't hold me reliable though, just saying my experiences.
Please don t go under the truck without the proper jack stands too because you don t trust the ramps. I guess you ll be OK cause the wheels will still be on anyway.
+1
I use the sheet metal ramps when I change oil, which are WAY too small for my tires. But I also chock both rear tires, put small 4x4 blocks under/inside the ramps....AND I use jack stands under the a-arms.
thanks guys
I have a jack, I am not sure what it is rated for. If I do jack it, where do you put the jack, under the rear dif? Where should I put jackstands, under the frame?
Yeah, jack it up from the rear diff, but make sure its planted WELL in the jack cup. Once its up enough for the jackstands to fit under, put them under there and adjust them up higher as you jack.
thanks guys
If you put the truck on the ramps and put the jack under the diff, you should be plenty safe. Just make sure it frrls nice and sturdy before crawling under.
could I use a 2 ton jack? The biggest jack stands I have found in stores were 3 tons, are those ok?
MORE than enough.
MORE than enough.
:lol: Just don't crawl under there with only the jack holding the truck up.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
