Wet Okole Or Cover King Seat Covers?
So i did some searching on the forum and found a few posts on seat covers. I have narrowed it down to either the Wet Okole or the Cover King covers. Does anyone have any critical info to persuade me on one or another?
My 09 Sierra has the almost white interior seats and I use my truck to work, so this color isn't working!
Any opinions would be great
Chris
Up to you really. Pretty much everything I get for my truck is for function over fashion. I have the same seat color as yours I believe and I bought some cheap covers for it. For a work truck I wasn't to concerned about the fit and look.
I have the neoprene seat cover from cover king on my truck. They still have the rear seat picket. I mesh 2 tone color. They are nug on the seats so they dont move around. i came with the headrest covers and also the center console pieces.
I also have CoverKing neoprene seat covers and I have no complaints.
Same here...Washed them recently and they look almost new. Only complaint is most people take it as an excuse to get in my truck however dirty they are...
I had the Wet Oakley on my Jeep Wrangler and they faded fast, though keep in mind it does not have a top on it 3 months out of the year and that it is exposed to the sun quite a bit. They held up good for about the first 2 and 1/2 months I had them but then the stitching started to come apart. After about a year and 1/2 of them being on my Jeep they finally gave in and the driver side ripped totally so I just took them off. Not for sure if it was because of the sun exposure but I don't think I would spend the money on them again. That's just me though.
Justin
I have the coverking neoprene covers and love them. I have an extra set that I would sell cheap that is brand new. I pm you about them.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
