I Once Knew A Guy
ALange
from Nantucket, who's DwonK was so long, he could s...nevermind. :D
WOW....
Now THAT my friends is hunglo!
Who's tongue was so long he could lick his eyebrows,women loved him :D
didn't take long for this thread to go to the sh*tter :drool: BTW,hi Art haven't seen ya for a while,been busy?
...who SOOOO wanted to be accepted that he started a thread, asking what the best thread topic would be for him to start...
:D:drool:
that FINALLY got his rear end gears installed. :D
WOW that guy must be a slacker for sure...
that got stopped for a DWI, officer gave him the option to park the truck and walk home,1/4 mile (gave him a break)well he did park the truck and the officer left so he walked back to the truck and drove off, same officer caught him and locked him up for DWI. :D
Now THAT is stupid.
who's dad was nice enough to sign over his '77 GMC p/u and a couple of months later ran it into a tree and totaled it 'cause he wasn't used to big block power(has a 305 again now). :D
Who's tongue was so long he could lick his eyebrows,women loved him :cool:
didn't take long for this thread to go to the sh*tter :lol: BTW,hi Art haven't seen ya for a while,been busy?
Hello Gramps,
I have been busy and I have been lurking over at USGT. I ignored my roots for a while. I am getting ready to head stateside in a couple weeks for some riding. I am not sure which direction I will head but it will probably be south, east, or west. I picked up another sled that will probably end up being my youngest daughters. It should be delivered by the freight forward company by the time I am home. Are you ever going to make the leap from dirt to pavement? I'd love to kill some bugs with you. First bottle of Crown is in me.
Who's tongue was so long he could lick his eyebrows,women loved him :)
Hello Gramps,
Not sure about doing alot of pavement riding,don't do much,but I do ride my XR600 on the street to do local errands(it's street legal FTW).I'll ask around,maybe I can borrow one.Glad to see you're comming stateside,I'm sure you're glad to be going home.I know you were here for Xmas,so it looks like you try to come home twice a year or so.
Man that's a nice Beemer you just picked up..I was checking out the front suspension and sure does look different.Is that someting new? BMW is always coming up with someting innovative. It kinda looks heavy though?How big is the engine?
As far as the Crown goes.....bottoms up :thumbs:
Who's tongue was so long he could lick his eyebrows,women loved him :(
didn't take long for this thread to go to the sh*tter :D BTW,hi Art haven't seen ya for a while,been busy?
Hello Gramps,
As far as the Crown goes.....bottoms up :cool:
It is a 1170 CC that is set up for cruising torque not pavement burning power. It is the last year (2004) of the cruiser model and has less than 1900 miles on it. I bought it as an extra for guests so if you ever make it to Idaho its yours. Light and very well balanced and nimble in the twisties. I am so used to my brutish hog that I wouldn't know how to behave with a lithe and limber dancing partner. BTW, to me anything under 800 pounds is light. It weighs 519lbs dry.
    RyGuy43
    RyGuy43
  • Who's Online   0 Members, 0 Anonymous, 432 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
