Aftermarket Cup Holder Insert?
i know i know...cup holders :cool:
2003 'burb
but I'm wondering if there are aftermarket inserts that would fit a Nalgene bottle that would snap into place of the OEM insert. Currently, the holders are only big enough for those belly buster cups that taper near the bottom.
Just wondering if anyone has any information.
what is a .... Nalgene bottle....?
A Nalgene bottle is a 1 quart bottle, typically used by hikers/outdoorsmen. They have a fairly large diameter. The older ones at least were the same diameter the entire height minus the top where the lid screws on.
This is a Nalgene bottle. They are great and nearly indestructible under normal circumstances.
They do make smaller ones too though.
Those things are awesome....
They are even indestructible under abnormal conditions. I bet a friend he could not break one with a 18-20oz hammer. He couldn't do it (this was on carpeted floor btw). It made some nice dents though, but still completely intact.
The Nalgenes from 8-10 years ago were awesome, some stores would tell you "stand on it" it wouldn't break. The newer model flexes a lot more, you can partially collapse the sidewalls with your hands, couldn't do that with the old ones.
Not saying it's bad or anything, but they changed the design a little bit. They might have done that so the bottle could handle a drop on rocks or other hard surfaces better.
I can't deform mine more than a couple of millimeters or so with both hands squeezing.
A buddy of mine tried pretty hard to break his. Hammers, bricks, throwing it, etc. He "said" he drove his Cherokee over it and didn't break.
I think eventually some Liquid Nitrogen did the trick . . . :cool:
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
