7 Wire Trailer Connector Question!
I need my 12v trailer wire to work and it doesnt and the fuse IS good and cant find corroded or broken wires Please HELP!!!!
First thing always is to spray with WD-40 and work the plug in and out a few times. Corrosion you cant even see can keep it from making contact. Sometimes you need to move the trailer around on the ball to get a proper ground also.. Good luck.
Thought there was a ground wire in the 7 way connector, the center pin if I remember correctly.
I stand corrected, the white pin is ground. http://www.etrailer.com/faq_wiring.aspx
Get a mutlimeter, you can get one at Harbor Freight for $3 if you don't want to spend much, and test between ground and the 12v. It should also have the diagram on the 7 way outlet cover.
These wires can usually be traced "by looking" as opposed to needing a wiring diagram (as would be the case with hidden and inaccessible wires).
If you don't get voltage at the connector, just follow the wire up all the way under the vehicle to the front and inspect it all along its run. Feel back behind the harness (where you can't see) with your hand for cuts in the cable. Check every connector along the way. Unplug any connectors along the way and test for voltage with your multimeter.
When you say "the fuse is good", are you refering to the fuse in the underhood power dist. ctr.?
I know in my case (2003 HD) there was a dummy fuse in place. I had to insert a fuse (30 or 40 amp not sure) to get power to the terminal that provides juice to the trailer batt.
RJ is correct !
03 and up GM put a dummy fuse in stud #1. Also note
the position of the 12v trailer batt. power pin is different.
Use a test light to verify !
I went thru this when I tried to use my 01s factory supplied trailer
plug leads on my 04......................
I've heard of them using dummy fuses a couple times now that you mention it. What is wrong with GM. Why didn't they either leave the spot blank or put a real fuse in, doesn't make sense to me.
Why? Simple.....DE-contenting !!!!!!!!!!!!
03 was a fine year and GM got CHEAP..............No more fuse in either stud1 or
stud2, no more free trailer 7 to 4 cord, no more trailer brake underdash cord,
no more floor flood lights, no more bang strip on each side of the bed, no more power lumbar, no more underhood light, one less power outlet etc............
There are a few other goodies GM took away....Who knows the ones I missed?
Well i have a real fuse and i checked with a test light and i got power on the stud #1 and i followed the wires from the connector up to the cab so far and so far no broken wires and there is absolutely zero corrosion anywhere. So not sure what to do next. Im at the point im about to run a wire right from the battery to the plug with an inline fuse!!! Im getting frustrated but oh well i guess :lol: Theoretically that wire should go from that stud #1 right down to the back right?? I would think so.
There is no way to tell where the wires go (if you can't follow them) without a factory electrical manual.
How many amps is that fuse and where is the fuse located? (Inside vehicle or under hood?)
The +12 volts to a trailer should be around 25 or 30 amps.
If it is a low amperage fuse INSIDE the vehicle, it may go to a relay under the hood and the contacts of that relay would be on another high amperage fuse.
And if there is a fuse/relay under the hood, then the wiring should go from that, under the vehicle, and to the trailer plug. This would be exposed and you could follow that wiring.
The wiring from a relay under the hood to a fuse for the relay inside the vehicle would be impossible to follow because it would be intertwined in a mass of other wires.
But I am just guessing without a wiring diagram to look at.
BRIMS..............If you haven't already found out...........
Wait till you go to hook up both the trailer power lug in your rear plug
AND your aux. trailer brake controller in your GMT-900 !!!!!!!!!!!
Neither wire is hooked up and just left loose under the hood hidden near
the underhood fuse center for YOU to hook up. Plus NO more plug n play
for your trailer brake controller either like the gmt-800s.
There is a thread with instructions and pics around here somewhere!
Ya, but putting in a dummy fuse can't cost much less than a real fuse, so why put anything in the hole. I understanding they were, and still are, trying to cut corners.
Ya that whole mess is just stupid. And on top of them not connecting you have to cross the wires. Why was it so difficult for them to have the studs swapped around? I have looked at that many times and am just dumbfounded.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
