Officially Converted To Gm
After almost twenty years of Fords I bought the 2003 Denali I was looking at. It has 118K miles and has had its 100K service. Mechanic upon inspection found a few things that need to be fixed, seeping rear air shock, seeping oil cooler line, needs tires, a/c belt needs replacing. They are on my list to fix asap. I am picking up tires (parelli's) at a buy 3, get 1 free deal. Got the XM radio subscription going, now I can listen to all the hockey news! I have a few questions about this vehicle, though and was hoping y'all could help me out.
Are the gauges on the dash real or are they idiot gauges?
It has the bigger engine (6.0), does that mean it has the heavier transmission or the regular one?
What do the buttons do on the right side of the NAV/Radio unit?
If someone is driving and accidently hits the 1 or 2 button (the memory seat adjusters) will the seats suddenly start moving while you are driving? Seems an accident waiting to happen if it does.
If we are listening to the XM radio while driving, can the kids in the middle seats listen to their own FM radio station through their headphones?
I love this truck.
Thanks.
I love this truck.
Thanks.
Congrats and welcome to the site! Sorry, I am not much help with your new truck but read your owners manual, I am sure it will answer a lot of your questions?
I believe with the bigger motor you would also have the bigger tranny? And the seats, I think they only work upon entry or idle, not while it is in gear? Good luck.......Irv
I love this truck.
Thanks.
I am not sure if the gauges that you are referring to are the stock ones or if the previous owner installed additional ones. if there are in the cluster (usually with the orange needles), then they are stock and tell you everything you need to know regarding the regular operation of the vehicle. The Denali has the DIC system: Driver Information Center that reads messages to you such as: TURN SIGNAL ON, DRIVER DOOR AJAR, AUTO HEADLIGHTS ON/OFF, OIL PRESSURE, FUEL ECONOMY, etc. Whenever you hear a chime, by usually looking at the screen under the P R N D indicator usually tells you whats up. The 6.0L engine means that you should have the 4L70E, but it is hard to say with definitive assuredness. Check the glove box for a sticker labeled SPID or Service Parts ID Card. That has 3 digit alphanumeric codes that correspond to what was installed in your truck from the factory (option codes). for the tranmission, look for the following:
http://www.nastyz28.com/gm-rpo-codes/rpo-m.php
I would have to see the NAV unit since I dont remember which is which anymore (used to be crosstrained on the NAV units).
The memory functions should be disabled when the vehicle is in drive and rolling past 8MPH (unofficially with respect to the BCM)
If the truck has a separate mini tuner that is integrated into the center console, the kids should be able to listen to the FM stations using the headphones.
Welcome!
Here's my two cents to your questions:
Q. Are the gauges on the dash real or are they idiot gauges?
A. Real.
Q. It has the bigger engine (6.0), does that mean it has the heavier transmission or the regular one?
A. Not sure, sorry.
Q. What do the buttons do on the right side of the NAV/Radio unit?
A. Which NAV/Radio do you have? A picture is worth a thousand words. ;)
Q. If someone is driving and accidently hits the 1 or 2 button (the memory seat adjusters) will the seats suddenly start moving while you are driving? Seems an accident waiting to happen if it does.
A. You seat will not move once out of Park.
Q. If we are listening to the XM radio while driving, can the kids in the middle seats listen to their own FM radio station through their headphones?
A. Does it have the radio controls in the back? If so, yes. Again, a picture is good so that we know exactly what unit you have.
If your listening to XM, the back radio controls will tune to any local radio station FM/AM. It can not tune to another XM station and can't tune to XM if the front radio is tuned to FM/AM station. This is the way my system operates anyway.
I had a Ford, once, after driving Chevys for 13 years, I decided I would buy a new Ford. Kept it 17 days only to trade it for Chevy, because it was the most uncomfortable ride next to my go-kart.
I'm pretty sure u have the 4L65-E with the Denali because you have the 6.0. To have a 4L70E you would have to have a 2006 truck or SUV.
I'm pretty sure u have the 4L65-E with the Denali because you have the 6.0. To have a 4L70E you would have to have a 2006+ truck or SUV.
^ What he said! :rollin:
Welcome to the site and welcome to the GM family! :thumbs: Do you have an pictures of your new purchase? I and I'm sure lots of others would love to see it!
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 588 Guests (See full list)
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
