Hummer H2 2003
s9696
I have problem in my H2 after I change the front arms
All light in the dashboard is on
1- Check Engine Lights</SPAN>
2- ABS
3- Handbrake
4- TC
For the Check Engine ( I change the knock sensor and O2 sensor ) it’s gone then it back.
For the ABS and TC and Handbrake ( Some garage told me to change some sensors in the rear differential ) but no thing happen
And now I change the hall transmission and I have new problem
The gear stuck in the firs gear.
And this is the DTCs reading from HP
[PCM] P0135 - HO2S Heater Performance Bank 1 Sensor 1 (SES) (Old) (History) (Current) (Immature)
[PCM] P0502 - Vehicle Speed Sensor (VSS) Circuit Low Input (Pending) (Old) (Current) (Immature)
[brake] C0046 - Brake Pressure Sensor A/B (History) (Current)
[brake] C0050 - RR Wheel Speed Circuit Malfunction (History) (Current)
[brake] C0041 - Brake Pedal Switch B (History) (Current)
[unknown] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Personal Comm.] B2470 - Daytime Running Lamps Fault (History) (Immature)
[Convenience] U1000 - Class 2 Communication Malfunction (History) (Immature)
Continuous Tests
Misfire: Complete
Fuel System: Complete
Comprehensive Component: Complete
Once Per Trip Tests
Catalyst: Incomplete
Heated Catalyst: n/a
Evaporative System: Incomplete
Secondary Air System: n/a
A/C System Refrigerant: n/a
Oxygen Sensor: Incomplete
Oxygen Sensor Heater: Complete
EGR System: n/a
Can any one help me
You have SERIOUS problems!
I suggest you take it to a GM dealer for service.
The "class 2" problem has to do with a computer network. EVERYTHING on the vehicle needs these computer networks to operate properly.
This is advanced troubleshooting to track down these problems.
