Got My New 2009 Sierra Denali Today..
And I couldn't be any more satisfied! I love that 6.2l Vortec.. feels nothing like my wife's Tahoe with its 5.3.. Took it home for $45k, with the sticker price being near $49. Maybe not a great deal, but it was well worth it, IMO. I defiently plan to get it tuned sometime in the next couple of months. I would have gotten black, but the white one had the options I wanted. And, the black one had AWD, which I later decided I didn't want.
Fairly fully loaded, with heated/cooled seats, Nav., and chrome 20's. Definetly a nice truck. I even got a complement on it from a guy the first day I got it! :)
Here are some quick pics I took, they aren't great but I will get some better ones later. :thumbs:
Damn, Nice truck. When you get a tune make sure you do a live tune. There somthing differnet with the transmission Tcm. Thats what I heard somewhere just to let you know.
Nice Denali :thumbs:. You should have made them throw in some running boards. Does the truck have a sunroof?
Nice Denali :thumbs: . You should have made them throw in some running boards. Does the truck have a sunroof?
Actually, running boards were part of the options, however I personally don't like the look of them on the Denali for some reason, and told them not to put them on.. I may get them eventually, because the truck does ride fairly high and it a challenge to get into. :)
I knew I had left something out.. Yes, it does have a sunroof.
Check out the rampage streamline 5" steps...I think they look great on my denali (and I've NEVER been a fan of steps)
Actually, running boards were part of the options, however I personally don't like the look of them on the Denali for some reason, and told them not to put them on.. I may get them eventually, because the truck does ride fairly high and it a challenge to get into. :thumbs:
About the running boards...since you don't like the looks of them, you may want to check into getting the "RETRACTABLE" ones like they have on the Cadillac Escalades.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
