03-06 Navigation Retrofit
ok yall, I tried to post about this at FSC but they dont seem to know/care anything about the matter.
Looking at the idea of ebay style retrofitting my 05 sivlerado with an OEM non-lux navi system. I think it would come in handy for other users (and yes I searched, I didnt find everything I needed..) to have a thread that has ALL the part numbers that you need to retrofit an 03-05 with navi both lux and non lux.
Here is what I have so far:
lux is repersented by "Y91" on your build sheet and is not common on silverados, but tahoes, suburbans and the sierra denali may have it.
lux uses a different amp to power the speakers, and a different headunit for navigation (and possibly for standard radio??)
part numbers needed for lux conversion??
bose to navi conversion.. no Y91 part number, what I'm finding is 2 part numbers for oem nav. unit.
15800000 as a "navigation radio" according to gmpartsdirect.com
15229287 according to forum searches google and 1 ebay listing.
Now, other than this you also need the GPS antenna..
88987710 as "Navigation antenna coax cable" according to gmapartsdirect.com
is this all you need? I recall hearing from a successful swap that some sort of gauge cluster to navigation headunit harness was also needed in determining vehicle speed.
Anything else yall please fill me in. Or if a thread exists that I just missed.. point me in the right direction if you dont mind.
huh.. no reply here either?
not even a "USE THE SEARCH!" ??
I know its not the current model.. but these parts seem fairly inexpensive and I see 03-06s everywhere..
15800000 is the part number I used in my Bose 04 Avalanche.
Your harness might already have the VSS wire for the vehicle speed, but if it doesn't you don't need it. I didn't hook it up. The Nav was very jumpy for the first few days then settled right down and worked fine.
Here's some pics I took when I was removing it(lease return). I also had a PAC adapter to run an amp and sub.
http://s609.photobucket.com/albums/tt175/K...valanche%20NAV/
thanks yall. I didnt know enough about it to search for "tnr800"... I kept searching for "navi" "navigation" "touchscreen" etc. and wasn't finding anything..
I can tell you right now from those pics, my truck has 2 harnesses. the large grey one, and a smaller black one.
