Navigation Radio Not Working
Hey fellas :omg:
I'm wondering if anyone else has ever experienced the following issue. My truck sat for about three weeks without having been driven. Of course the battery died (both of them, actually) and I had to charge them up. It took a couple cycles, but the batteries finally took the charge and they're working fine. The issue is that the navigation radio won't start up. There's just a black screen--doesn't seem to be getting any power at all. What's the problem here? Did I trigger the anti-theft system or something? Any insight would be appreciated :dunno:
Hey fellas :omg:
Not positive, but I thought the radio would have "Locked" on the screen.
All GM trucks went with VIN controlled security for radio systems in 2003. You should never left your vehicle sitting for three weeks without a battery tender to keep the battery fully charged. Three full discharge cycles will kill a lead acid battery.
the radio in you truck has the vin number programmed in it that it compares to the one programmed into the BCM so it will not go into theft lock unless plugged into a different vehicle
Turn off ALL ELECTRICAL things...AC...Radio/NAV..etc..etc
Disconnect BOTH battery cables...
Touch them together to discharge the capacitors.
Reinstall the cables, connecting the NEGATIVE cable LAST.
Start truck...turn on Radio/NAV.
Yea, I was thinking that should be my next step, Jim. The thought of pulling that unit out, though :D
Oh, well. By the way, I have the truck listed for sale in the For Sale section, if anyone is interested.
Yea, I was thinking that should be my next step, Jim. The thought of pulling that unit out, though :(
What? What are you getting next?
Probably something with a working Nav Radio. :)
(Sorry, Will, I had to!) :lol:
Haha.
So I pulled the "Radio" fuse under the hood again today, and took a closer look at it (pulled it a couple days ago, too). It looked fine, so I put it back in. I started the truck up, and now everything is working. I'm just chalking the whole thing up to an electrical gremlin causes by the battery issues. Just glad I didn't have to yank the Lockpick.
No clue. Maybe another coupe.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
