How To Grease The Slip Yoke
I have the dreaded clunk and I am going to grease my slip yoke this weekend if I can find the time. I don't have a problem removing the driveshaft but I want to make sure I'm greasing the slip yoke correctly. Does anybody have a picture of where to grease the slip yoke? Inside or outside of the yoke? I know this has been beat to death but I've searched and can't find a picture, so if anybody has a picture or a link to a thread with a picture, it would be appreciated.
I'm going to use the Valvoline Grease that I found at autozone that says it meets GM specs on their grease and it says it's forumulated for all GM vehicles. Is it ok to use this grease?
  • Replies 99
You don't need any pictures. What you do is take the bolts out of the back of the drive shaft holding it to the rear differential. Pull the shaft out of the transmission. Look inside the slip yoke, you'll see splines. Put some grease on your fingers and pack it into the splines on the shaft. Once you feel you have enough in the yoke, re-install the shaft. You'll find it's harder to slide back in because grease does not compact. Re-install the bolts and your done. :cheers:
Thanks Steven. I figured once I tear it apart it would be pretty obvious where to grease so it was probably a stupid question. I'm trying to pass the time at work 'til 5.
Specs on the grease:
-Extreme-pressure, high-temperature protection
-Lubricates at temperatures ranging from -40°F to 400°F
-NLGI #2 Grade GC-LB Lithium Complex EP Grease
-GM 1051344; NLGI GC-LB; Supercedes GM 1051195
I should be good to use this grease on the yoke?
many folks also clean and coat the outside of the yoke lightly. some theorize that the seal is hanging up a bit keeping the yoke from sliding freely on the splines. Some also use emery cloth or steel wool to clean the rust off the outside of the yoke where it fits into the trans. If I had mine apart, I would take a few extra minutes and do the outside also, just to avoid taking it apart again if it helps....
Don't forget to mark the shaft for alignment for when you put it back in. Some say it isn't required but it doesn't hurt to put it back together the same way you took it apart. :cheers:
Gentlemen,
Can't you just grease the zerk fitting?
Ken
There are no zerk fittings on the slip yoke. The only fittings I know of are on some after market u joints. And thats at the other end of the drive shaft. Kinda hard to have a zerk fitting in the transmission. would be nice though.
I'm thinking mine has a blind spline and only goes in one way.
That would be great. I wasn't sure on the newer vehicles and I have not taken mine out to know if it does or not.
+1 I'm pretty sure also. But mark it just in case. :jester:
Zerk fittings have been left off for several years now. That's why on the newer trucks there are only 2 places to grease
Rotation of the driveshaft in relationship to the output shaft of the transfer case/transmission doesn't matter. I have a two piece rear shaft. The slip yoke between the two sections is greasable, as is the slip yoke on the front driveshaft.
No, this is just general purpose grease and not thick enough for this job. It will work, but not as effectively as recommended greases. I would try either the GM tech bulletin recommended grease (=expensive), or Marine Triple Guard grease.
Where can you find that in town?
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • My centre console USB ports haven’t been working and the one in the glovebox is starting to act up. When I plug my phone into the cord the radio will go black and stop playing, and the CarPlay is inconsistent.   I checked the fuses and they were fine. I changed the USB port out and still nothing. Hoping for some advice on what I should be looking at.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
