Tranny Additive
I have an 01 chevy express cargo van i picked up real cheap it has a 5.7 and a 4l80e the mileage is almost 180,000.I just changed the fluid and filter, seems no better no worse. ive had a bunch of trucks with the 4l80e and never had any problem but never with this many miles,
So im looking to see what you guys recomend for an additive to maybe firm shifts up and just make it a little tighter. feel better. thanks
I would not recommend putting an additive in the transmission. As for the shifts I would say enjoy it and hopefully it will last a long time.
why add something now. Let it be and enjoy your lucky transmission.
The 4L80E as long as it hasn't got to hot will last a long time. I had 365,000 on my first tranny in my last dually. Sold that truck with 567,000 on it. It was a 4L80E and it seen alot of heavy towing. The only thing your 4l80E will like is if you add a bigger transmission cooler on it. The small one from the factory is ok at best. As it ages make it run cooler. If you want to run an additive in it put the Lucas Transmission treatment in it. That will help with sticky valves etc. No you don't have to drop some fluid out to add it. I am sure I will get flack about that from other posters but I have used it in the past with good result. As long as there wasn't any metal in the pan you should be okay. Just my opinion.
Thank you for the reply, I thought about the lucas but just figured i would ask first, i will look into the bigger cooler. thats the coil right in front of the a/c evap coil right... do they mahe a bigger eplacement with the same connection fittings, Thanks again
I used Lucas in an old Ford explorer that was slipping a little....it seemed to help the shifts and slipping in 2nd was all but eliminated....I ran it about 8-10,0000 before I sold it.
I don't think GM makes a bigger cooler....I asked about one for my truck, and the dealer said there is nothing available....so it is back to the fabricating table...ha
    • I installed the Auto stop eliminator on my 21 Sierra SLT shortly after I got it. They have a detailed video instruction on how, took me about 20-30 minutes to do. I was apprehensive too to start tearing apart a new truck but it was pretty easy install. Like you mentioned get some trim tools. I went to Harbor freight and picked up a set. If you can find some install videos/instructions to give you and idea for a plan of attack you should be fine.
    • If all oil manufacturers had to meet a higher standard for not just the initial filtering of the oil but that they had to improve on their formulation so that the oil cleaned the engine such as the Valvoline R&P or the new Mobil product ( assuming it works similar of course ), and the oil was changed on an interval based on good UOA data, there shouldn't be any gremlins running around like miniture rats on top of your heads to be washed down into the oil pan below 😁
    • Worst factory HD wheels GM makes
    • A while back on another thread there were comments and thoughts on air filters and I know that can tend to be a bit of a hot topic because of outfits that have a vested interest in selling aftermarket air boxes fitted with the gauze type of oiled elements touting the lower air restriction. However and unfortunately I don't know where I have seen the test results in the past about the amount of dirt through a test procedure that these style of filters do pass more dirt through than a properly designed ( not some cheap Chinese knock off ) paper/synesthetic media filter can do. Lake Speed had a conversation on that topic with one of the employees at Donaldson and there seemed to be a consensus of these oiled filters falling short in the absolute percentage of dirt holdback.    Which all ties back into how good the air filter is on the engine at keeping dirt out as that is going to reflect as a contaminant introduced into the oil as well as cylinder wear even if some of that dirt does find its way out of the exhaust rather then the crank case. Put another way that one can throw the kitchen sink at filtering the oil and using a bypass system which I fully expect will do nothing but good for the oils contamination but if the air filter system isn't doing its job then its preventing the engine from reaching the best wear/lasting case scenario instead.    Now perhaps this topic is or isn't for this particular thread but Grumpy Bear or anyone else for that matter, do you have access to some scientific trust worthy testing on engine air filter types to get some proper comparison data to post up.
    • WOW, something we agreed on. I only bought at sticker twice. A 94 impala ss and an Acura intagra type r. Made money on the first. Still have the second.
