Thinking Of A 1.5" Bl
I'm tossing the idea around and considering adding it to the pot of other stuff I wanna do to the truck this summer... Question though... Would I need gap guards with only the 1.5" body lift? If so would the GM wheel wells cover it up or would I have to fabricate something up?
gm wheel well liners should do it
Yeah I'm not looking to get the huge truck look. A 1.5" makes it look real good... Thats what I'm going for is just to give it a bit of lift and make that appearance that much better
I have the 1.5" BL and the gm rear covers will cover that gap. I have didn't have any gap guards on my truck for awhile and no one can tell I have a body lift at all. I am installing the GM rear covers this weekend if weather permits.
:thumbs::thumbs: And next week the Covers will be posted in the "For Sale" section :tear::sigh:
No they will not. I have to custom cut them to clear my airbag brackets.
If I ever get a body lift I will probably get the 1.5" from zone because it does not extend the steering wheel, I dont know why but feel unconfortable with the idea of a steering wheel extender wich comes with all 3" body lifts
For those of you with a 1.5" body lift how hard was it to install? zone says 3 to 5 hours for the 1.5" body lift and 8 hours for the 3" body lift.
1.5" took me 3 hours by myself and hand tools. The 3" took me about 3 hours too, by myself. EASY!
what tools do you need?? Anything special? I am probably just going to add the 1.5" and put it on by myself. (i feel like maybe the 3" with the fabtech would make 35s look too small?!) I havent looked at any kind of instructions, I am assuming the zone kits come with install instuctions.
Just thinking aloud really for any kind of tips I should know about b4 putting it on.
Go with the 3". Your 35's will look fine.
yah it looks fine on yours but I dont want step bars and I have the GM perfomance exhaust and Im not about to cut that up to hide the tip
The frame exposure isn't bad at all. It really just looks like an HD with a 3" BL. As far as the exhaust tip, can't you just shorten the hangers? :lol:
The frame exposure isn't bad at all. It really just looks like an HD with a 3" BL. As far as the exhaust tip, can't you just shorten the hangers? :thumbs:
That might work. I'll look into it. I still have a couple months till the weather breaks so I got some time to mull it over yet.
    250.3k
    user087
    user087
  • Who's Online   3 Members, 0 Anonymous, 843 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
