Funny Noise From Take Off Once Stopped
I have a 2006 Sierra 1500 4x4 ext cab and recently I have been hearing a funny noise when I take off from stop or very slow under 5mph and give it gas. Its a 'whooop' (forgive me for trying to spell it but its a different kind of noise) and its only when I give it gas. Especially on hills when you are already coasting back so you give it a bit of gas to get going. I thought maybe brakes and I changed them anyways for inspection but still have the noise. It has 54,000 miles, nothing seems loose underneath like a shock bolt or anything.
Its not a horrible loud noise but you can hear it when it happens with the radio turned down. Feels like a pulling noise like something is trying to let go then it does only because I gave it gas. I even coasted to a stop not using my brakes and it gave her gas and it still did it so not brakes. Just wondering if its something anyone has heard of before? Everything else is great on the truck.
Come to think of it, it almost sounds like the noise your locking rear end makes when both tires spin. Maybe its rear end related? I know its a tiny bit low and I have the oil to put in it but I know its not dangerously low. I know the hillside thing makes sense now but I am NOT spinning tire at all. It will do it on the level as well as grades and its not enough power to be skipping then locking up.
Thanks and it does have a locking rear axle.
Have you checked your drive line u-joints? T-case? I wouldn't describe the sound of a locker going "whooop". More like a clunk
The only clunk I get is from my driveshaft and we all know they are known for that...the joints look good, have not checked the T-case...what might be the problem with the Transfer case?
when my locker kicks in on turf or snow, it does not 'clunk' at all. It makes a pulsating noise until I get grip. This is like one single pulsating noise, not many like when you are locking the diff up on wet turf. I only time I hear a clunk is if I hit the 4x4 on while giving it gas...and that does not happen very often.
GM had a problem in early 2000's with the driveshaft splines sticking in the back of the trans or transfer case. It made the same noise as you are describing. Pull the driveshaft, lube splines on output shaft, reinstall.
They also had the leaf springs make a noise between the leaves. Spray water on them( or WD40) to see if this is the problem.
My 06 CC/SSB Z71 does this. I think it's rear end related, either the brakes or the fluid. I used to get the noise a lot changed the rear end fluid and rear shoes/drums and it went away. 45K miles later it's back.
I'd describe mine as a quick squeak, higher pitched. You have to come to a complete stop to get it to do it. I almost at first would wonder if it was a bad bushing and as the axle rotated from torque input it would twist.
+1 Slip yolk noise.
Thank you for the help. It probably started around 50,000 miles or so. I will do this and see what happens.
+1 Slip yolk noise.
    • Did the KYBs keep it the same height in the front? I was concerned that pre-assembled assembly would raise it up an inch to standard non-z60 height.. I guess which it would make the rake 1 inch instead of 2 inches.
    • Thank you for keeping the train on the tracks and for a thoughtful engagement. I enjoyed the reflection on a previous stance to refine and improve your position. I like that inquisitive flexibility about you Atlas.    No the process isn't sterile. Hundreds, perhaps thousands of miles of piping, vessels, pumps. Chevron, the people I worked for, were keenly aware that there is a market for what is known as their "ISOCLEAN" line of lubricants. These are lubricants that are the same as those sold bulk that are further processed by filtration to a level your particular application demands. They will filter and package and provide lab documentation as required. Do not kid yourself. Every gallon of oil that goes into a Chevron Turbine, reciprocating compressor, generator is prefiltered and tested before being charged. Lest wise it was when I was there in the plants I worked in.    There are requirements set by manufactures for the cleanliness of the oils used in their equipment. OTR such as CUMMINS has standards shared with customers on this. Commercial interest selling to Ma and Pa do, but don't share that information. Not even upon request but internally, they do exist.    The GM study sited, (Graph from Machinery Lubrication in previous post) only shows "relative" importance.  I find that fascinating. By constructing the graph like this they admit there are dozens of factors in engine life and via scientific method determined the effect of 'relative cleanliness' on engine life not in miles but in 'FACTORS'. This allows a certain amount of reverse engineering does it not?   They even provided some touchstones. Beta 75 as a reference point. Wonderful stuff!!   Smaller blenders CAN and some DO take the time and effort to do better than a refinery or large bulk blender, like Warren Oil, in improving the "in the can" cleanliness. No I don't have a list but testing could generate that information.    Again, but one of several levers we can pull to improve engine life. The simplest is keeping a clean work station while doing your own oil changes.
    • Thank you. I'll give it a try
    • I just spent the last 45K miles doing samples every oil change over more than a full year to get the data for seasons and break-in to broke in.    I found the same thing to be true. Something was always teetering on done or had stepped off the cliff long before the OLM was DOA. In fact, I found about a thousand mile difference between summer and winter. That is during the winter half the OLM was STILL too long. Even the severe schedule was to long in the winter.   Now having done the work I can say I was NOT DISAPOINTED. I saw nothing I didn't already know. Nothing my father hadn't already demonstrated in his 2K OCI's pushing dated iron on dated oils and weak filters to mileages well beyond 300K.   Building on his work through use of Lab testing it wasn't hard to find the correlation between 'sight/feel/odor, the things dad relied on, and test results. Use of current viscosity stable chemistries & filters has pushed that marker for my motors out to 3K summer, 4K winter.    So the early lies were 3K on conventional oil and the lie upon the lie was 7K+. turns out to be off by a factor of two.    So... it is true that modern chemistry has doubled the useful oil life. But the base milage that came from was off by double. It's how good lies work. Partly true, sometimes mostly true so that your meter isn't set off. It also means that non-shear-stable shelf oils are only now as good as the old oils were in their best case scenario.    So the question now is how do we improve on that? Thus the question into cleanliness among the other items listed in the post quoted below.    If this bores you, feel free not to participate.
    • Is it though?  Like LTZ, not a high take rate.  Current Sierra has AT4, Denali and Elevation as its main bread winners.  Each trim accounting for 25-35% of sales for Sierra.  SLT makes up about 10-15% at best.        Like others have predicted here for GMC, it will be:   - Pro (equal to WT Chevy)   - Elevation (replaces SLE and SLT)   - AT4 (and X)   - Denali (and Ultimate).
