New Concept Motor From Ford
66nova
One of the comments:
Ford...you can't even get spark plugs right...this is far too big of an undertaking.
I guess the "new" Ford likes to pay out warranty claims on the junk they build.
:P
:P
You like that huh?
The concept sounds interesting...I just worry about the execution.
I think that in the next five years, we are going to see HUGE advancements in ICE engines. One that really interests me is the HCCI engines from GM. A gasoline engine that acts like a diesel...ie: no spark plugs.
Linky!
Matthew
2007 Silverado, Reg cab, LT1, Victory Red, 5.3, 3.73 Rear end Locking, On Star, Xm, 6 Disc CD Changer, Power folding/Signal Mirriors, 17'' Aluminum Rims, Heavy dudy Transmission, Locking Spare tire, Heavy Duty Trailing, Chrome Exterior Packge, Fog Lamps. Silverado Classic.
Mods- Top Deck, Bed Rug, Bilstein Shocks, Corsa Sport Exhaust, K&N Air Filter, Amsoil Oil, BFGoodrich All Terrian T/A's,Viper Alarm 5901, Hid Lights 6000k.
Tell me you spelled "duty" that way to be funny...
:P
BTW...you have any pictures of your 6000K HIDs. I am debating between 5000 and 6000...
Being a Chevy fan, I'm hoping that GM will come out with something similar or better. Do we have anything upcoming to be excited about....?? Anyone??
Yeah...three posts above yours...
  • 3 months later...
The gas stations are going to have to do a lot of upgrading to accommodate E85. It's hard enough just to find diesel.
There are more and more E85 stations popping up everyday. In WI/MN there's at least one gas station in each town that has it.
What I don't get is why mess around with a dual fuel engine when they could just design an engine to run off of pure ethanol? Cut down on the costs of the engine and instead of messing around with two fuel tanks there's only one. Some people are going to say because E85 stations aren't plentiful yet but you still have to fill up with E85 for this engine to work anyway.
This guy is thinking the same thing as me : "The engine will be well received. Lower cost, less weight, and better mileage. Ethanol is a good fuel. I would think the best place for ethanol would be trucking. Ethanol burns more efficient with high compression and turbo engines much like diesel. Fords Bobcat engine could as easily run pure E85 with no regular unleaded. We should be developing pure ethanol engines or better yet hydrous ethanol. The large vehicle market should be fueled upon natural gas and ethanol. This a better mix for the large semi's. Having dual fuel capabilities or triple fuel with diesel. Those commercial fuel stations a good place to set up hydrous ethanol pumps and natural gas.
Posted by: flee | Jun 9, 2009 6:44:00 AM"
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
