Ac Blows Heated Air
elvispresley
1999 gmc z 71. out of the blue my ac starts blowing heated air. on agian then off agian until now it is blowing heated air every time i turn the ac on. it stays blowing this hot air no matter where i set the dail blue to red. i do believe i heard the door flap shut the last time it switched.
can someone please point me in the right direction. if its an actuator, how would i determine which one and where. is there a schematic, or diagram that i could download.
any help is greatly appreciated.
This is usually an actuator problem. There are little electric motors which open/close doors which switch from hot to cold.
But knowing the exact location of the door in question, how your specific system should operate, how to troubleshoot the problem, and procedures for replacing the actuator (if that is the problem), requires the GM Factory Service Manual set for your year/model vehicle. You can order that from helminc.com or a GM dealer.
You would also need to know how to use a multimeter for troubleshooting.
How to use a multimeter...
http://www.google.com/search?hl=en&saf...ter&aqi=g10
thanks for the quick response. roughly, how much would that be? and how long would it take? {best case to worst case scenario} average mechanical skills.
my local jiffy lube mechanic looks under glove box, and says the dash has to come out. 5 hours labor he says plus the price of the parts. then he looks something up on the computer, goes back and looks under the steering wheel and says if he can do it in a shorter amount of time he would try to save me some money, but said to be expect 500 to 600 dollars.
i really cant afford that right now and am trying to save some money. so any hints, tips, or info is really appreciated. thanks guys
    • Okay boys and girls I put a bottle of this in Dizzy the oil burning guineapig after a tank between the coil and plug service of the #3 hole and near the end of the first R&P 5W30 attempt. As a note I did a two R&P oil changes back in October of 2025 with little effect. Granted they were 1K mile a shot oil changes so.... Then followed by fourteen  1K mile changes of Mobil 1 Euro 5W30 FS. Also ineffective.    Anyone who has followed the adventures of Dizzy may remember that to put the oil on the full mark of the published nominal 5 quart change I withhold about a cup of oil. That over the last 50K miles the P0420 light has been a frequent flyer, sometimes three of four a day. And that even on 93 octane fuel she registers some KR even in moderate conditions on favorable days on slight inclines. Lastly when giving her a kick in the pants, something done about once a week, she looks like a diesel with the pump turned up. 😬   After one bottle and over the last 500 miles of a 3K mile OCI, of the first oil change I dropped the nastiest looking oil ever in her history. That's saying something as  you will recall I have used AutoRx, HP EC30/40 and a few other harsh solvents in her before including the GM top soak twice. This was syrup. Black stinky, inky syrup but the filter wasn't all that bad.    On the second fill I had to use the entire 5 quarts to reach the full mark. That was unexpected! The ignition KR is completely gone! Even at 99% engine load. MAP is much lower. Level road is now 9.8 instead of 12.5. Fuel economy is remarkably higher and for the first time since her earliest days she will spin to 6500, more than a thousand higher with out laying down dead. Yes, the coil and plug had something to do with that but remember the first 2500 miles after that repair on the first change it was same ole same ole Dizzy. Seems we have top rings that are somewhat functional again. P0420 code only comes on now if run in town for more than an hour of stop and go. On the open road it goes weeks without a incident. Perhaps it is cleaning the cat on the pass through?  Fuel Trims have improved as well. Nothing not to like.    To early to say about oil economy but the changes to date in the operational aspect is remarkable. I can't think of a worse case than Dizzy.... It's already paid for itself in a few tanks of fuel with the mpg improvement.    @OnTheReel, I'd say if the Jeep didn't respond perhaps there wasn't an issue to respond to.    I've run the Red Line SI-1, AMSOIL fuel cleaner, GUMOUT and Techron all in this SUV without any such results. Color me impressed. I'll be running out my supplies of the list mentioned and moving on to the Valvoline R&P Fuel System Cleaner.
    • Hey Chuck !!Thanks for the all the info I'm an old fart and I have everything I need for the oil change at home,minus flexibility .... and I’ve been doing my own oil changes for 40 years. I just didn’t want to end up without a crush washer or with the wrong one in my stash and have to walk to the auto parts store, lol. I climbed under the truck to check the location, and man, it’s going to be the easiest oil change and filter swap in the last 40 years—right up there with my 2014 Mitsubishi Outlander 2.4. No mess, nothing to drip on—just perfect. I’ve got one more free oil change to use, and then that’s it with the dealership!
    • I think this subforum was created for the new generation pickup trucks (2027-) with the 3.0 but I don't think it's a big deal either way. There are probably 2027 model-year specific changes for the SUV's too.   I was just curious if you had issues with your 2025 3.0. I'm still under 10k miles on mine and fingers crossed I don't have thrust bearing issues. I'm guessing not, since you're willing to buy another one! It's a good engine minus one or two manufacturing whoopsies.
    • Wife has enough metal in her she hides from the scrapper.
    • Djannoyed was a one hit wonder. Posted and disappeared.
