Anyone have husky liners and the cargo system in their truck? I just know that I'm hard on carpet interiors. I live in Saskatchewan and one minute it could be snowing and the next it's melting. I deal with a lot of mud and crap so I just thought that this would be a good way to save some carpet life. I also really liked the idea of the storage thing because I always have crap stuffed under the seat and again thsi would save the carpet! I just wanted to know if you liked them? Any bad things about em? How do they fit? Any better brands? Or ones to stay away from?
I have them, they're ok. The main reason i got htem was because my dad had them in a 97 Jeep Cherokee and they worked great, they were deep and fit extremly well. In our trucks are not near as deep and the fit is ok but they do work pretty well. I would recommend shopping arround and trying to see the fit in person. There are definetly better ones out there.
1 word: Weathertech.
I have husky in my tahoe and had them in my silverado. Liked them very much. I already have the front and rear set of weathertechs for my new truck which isnt even ordered yet. I wanted to try something different and live on the edge. Either one I think are very good.
Just bought a Husky set off ebay for 50 bucks. They are very nice and well made. Probably not as nice as the weathertech but I was unwilling to blow almost $200 on floor mats. Look around ebay for the Husky if you are going that route.
I will check ebay. If not, I will bite the bullet and get them direct. With all the salt that gets spread on the roads here every winter, it is a huge chore cleaning the carpets each spring. I do have the OEM mats, but need alot more.
Agreed. Salt is not good for any part of a vehicle. Sometimes I wish the highway dept. would use sand instead!!
The Husky cargo liners I like. They have saved the carpet in everything we have put them in. I had problems with the front floor mats on my old dodge some, The mats liked to curl up around the edges some. I did beat the heck out of them on that truck though and they were easy to clean :rollin:
If anyone is interested, I have a complete set of Husky liners front to back for a 07 Tahoe (with rear buckets).
Tahoe's gone, liners still here in a spare bedroom...
PM me and make an offer :confused:
i have the huskys and have had several sets, never let me down. i like the weathertechs, i also would recommend looking into the fox weatherboots.
I've owned huskys in my last 2 trucks and love them. I work outside full time and bring alot of mud and dirt into my trucks and the liners protect very well. For the price they can't be beat. I also bought the cargo box for underneath the back seat but wouldn't do it again. The box shape eats alot of storage space and it slides around when put on the floor liners, if used without the back liners its alot better.
Had weathertech in my '97 and when I got the '05 told my wife I need to get liners and she bought husky for me at xmas. Both do a good job, but the weathertech is much better product quality IMO.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
