Evap Clogged Withlots Of Dust And Dirt
mikej8111
Hello,
i have a 2004 denali witha check engine light, error code that I believe is P0449 (i lost the paper i wrote it on) I was told that i only need to replace the cover or housing for the evap near the gas tank. I guess there is a new revision from GM. I guess this seems to be a big problem on GM vehicles that operate in dusty conditions. I have done searches on the GM part website, but i can't find it without buying the entire evap system. If anyone knows the revision # or the new part # that would be excellent.
Thanks!
Mike Jajkowski
Might try a GM dealer parts department. They can turn their computer monitor around and you can point at what you want.
(Then at that point they usually tell me I have to buy the whole thing! :confused: )
I found the new part # for a 6.0 - P/N 19207763 - This is the new revision from GM.
Phillips Chevy near my house wanted $158 for the part.
gmpartdirect.com wants $78
Thanks for your help.
Plus however much for shipping. Have you tried to negotiate with your local guy? Many times they will work with you once they find out you are an informed customer. :confused:
    • This video may not be the exact content for the joke thread but its a lot of laughs so here it is, I've only watched a portion of it so far but if anyone is looking for some light hearted good soap box driving action, its here. As a note in the upper left of the screen it shows the number out of 100 to refer back to any particular vehicle for comment !.    https://www.facebook.com/reel/1351928276956715
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • As a matter of amusement I’ll leave this conversation with this. Do you beat the government average fuel estimate? Statistics are a guide to me. Not a rule. Someone once said I have to have the last word. If true and possible may be. I’ll blame that on working in a family business.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
